Adding Insulation
Is there any way (without ripping out walls) to add insulation to your exterior walls?
Can you blow in insulation even if there is already regular roll type insulation in the walls? The house would build in 1963, using some kind of fiberglass insulation, but it does not look as thick as what we use today. (where I have seen it) Jamie |
The short answer is no.....
| All times are GMT -4. The time now is 04:12 AM. |
