Adding Crown Molding On Kitchen Cabinets - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-21-2013, 08:22 PM   #1
Adding Crown Molding on Kitchen Cabinets
Hello all,
If I posted this in the wrong section, please let me know.
I am interested in installing crown molding on kitchen cabinets. I have been researching and it seems like some folks take a much more involved approach and others just nail molding right to the cabinet front.
Do you suggest building a backer frame on top of the cabinet to nail the molding to? Or suggest just nailing to the cabinet front?
Any step by step guides or how-tos you can share?
Thanks!
Illini40 is offline   Reply With Quote
Old 04-22-2013, 05:23 AM   #2
DIY staff
Rewards Points: 7,174
How you install the crown has a lot to do with the cabinets themselves---
If there is enough wood above the doors to nail into and give you a proper reveal--then no blocking or nailer is needed---
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
forcedreno2012 (04-23-2013), mae-ling (04-22-2013)
Old 04-22-2013, 10:06 AM   #3
firehawkmph's Avatar
Rewards Points: 1,922
Like Mike said. Depends on how much of the faceframe is showing above the doors. When you see people adding wood on top for backing, it is usually with cabinets that have either 3/4 or full overlay doors. If you have standard overlay doors, you should have about 1" of the ff showing above the door. That it fine to attach the crown to. 18 gauge brad nailer works fine. I glue the miter joints and pin with a 23 gauge micropinner.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
oh'mike (04-22-2013)
Old 04-22-2013, 06:47 PM   #4
Thanks for the feedback guys. I will take a closer look at the cabinets themselves and determine the best plan.
The doors are not flush with the top, so there should be enough room to nail to the face.
Old 04-22-2013, 07:17 PM   #5
DIY staff
If you need to add a nailing block to the top----use screws from inside the top of the cabinet---
Small trim screws don't show much, if you don't want to see the screws----
Old 04-23-2013, 12:16 AM   #6
Retired & Not Likin' It
Jim McClain's Avatar
I used a cornice top on my upper cabinets, but the principle is the same. As Mike said, I added what I call a nailer (they're just scraps - the little piece is only glued in, but the longer one is screwed) to the tops of my oak cabinets by screwing up through the top of the cabinet face. I filled the holes with caulking - white for the white cabinet and tan for the oak. This allowed me to position the cornice trim so that the faux fillet piece fell centered on the seam between cabinet and nailer.
Jim
Adding Crown Molding on Kitchen Cabinets-kitchen-cabinet-cornice1.jpg   Adding Crown Molding on Kitchen Cabinets-kitchen-cabinet-cornice2.jpg
Jim McClain is offline   Reply With Quote
The Following User Says Thank You to Jim McClain For This Useful Post:
Old 04-23-2013, 08:12 PM   #7
Renovating My Land Yacht
Rewards Points: 616
Jim - great job looks elegant and not to busy.
forcedreno2012 is offline   Reply With Quote
Antiquing kitchen cabinets Beeba Painting 1 09-17-2012 07:22 PM
Cutting crown molding helpless handyman Carpentry 12 08-29-2009 01:30 AM
Adding Crown to Cabinets kimberland30 Carpentry 9 07-16-2009 03:58 PM
Kitchen crown molding eroley Carpentry 5 12-04-2008 09:24 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 10:23 PM
