Adding Crawlspace Vent - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-24-2011, 02:05 PM   #1
Question
Adding crawlspace vent
For some reason, a crawlspace vent was not installed on the front of my home. As a result, I have a small amount of mold in that area. I plan to install a vent and would like suggestions.
The wall consist of the typical construction of cement block with brick on the exterior.
I plan to remove one of the top cement blocks, just below floor. The big job will be cutting the brick on each side of exterior opening. The bricks are not solid and have holes through them. I know that I can remove the entire brick and replace with cut edge opposite opening and remorter.
Is there a better solution that involves less labor, like maybe a surface mounted vent?
Giles is offline   Reply With Quote
Old 08-24-2011, 03:55 PM   #2
Rewards Points: 5,332
Any vent needs the correct size opening. You need to cut through all the masonry to do it.
You might need a small lintel to support the bricks.
Ron
B. Franklin 1759
Old 08-26-2011, 06:59 AM   #3
I just listened to some handyman show on this subject.
Consider getting a small dehumidifier.
Bill7 is offline   Reply With Quote
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 05:47 PM
Please look at this dryer vent installation Andy Griffith Appliances 6 08-31-2009 12:39 PM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 06:34 PM
Adding outdoor wiring from crawlspace MusicMan_234 Electrical 2 06-25-2007 08:57 PM
