Adding Attic Insulation To Existing Insulation - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-08-2009, 09:12 PM   #1
adding attic insulation to existing insulation
We are trying to add batt insulation to our existing 5.5" cellulose insulation. My husband got R19 faced insulation. We understand that the vapor barrier may promote moisture. Will that be a problem if we install the insulation with the vapor barrier facing up. Please advise
strouddljs is offline   Reply With Quote
Old 11-09-2009, 05:27 AM   #2
Remodeling Contractor
then you will have a vapor barrier at top of the insulated space and one at the bottom. Sooo... moisture will be trapped... insulation ruined.,.. mold grows.... If you cannot buy the unfaced insulation that you should be using, then cut slots in the paper face to allow the insulation to breathe.
Old 11-09-2009, 07:30 AM   #3
Thank you. I will cut slats in the vapor barrier than exchange the rest of the insulation for unfaced.
Lesley
Old 11-09-2009, 02:59 PM   #4
Registered User
Rewards Points: 5,204
"I will cut slats in the vapor barrier" ---- as Bob said, slots ----- actually remove some of the facing, 3" down the middle. Not just slits with a knife which wouldn't do much as the moisture laden air is not forced through, but slowly rises from below. After the new install the slits would close all but the 1/16" hole from the blade, not nearly as effective as removing v.b. material to let the warm, moist air rise. I would pull all the paper facing off or paint the ceiling below with a vapor retarding paint (oil), especially over a bathroom, laundry, or kitchen (water source).
Be safe, Gary
Old 11-09-2009, 06:06 PM   #5
adding insulation to existing insulation
Thank you.
how hard could it be to add extra attic insulation? diy'er on LI Building & Construction 15 07-19-2009 08:07 AM
Adding insulation? kcrossley2 Building & Construction 2 12-03-2008 08:43 PM
Adding insulation to only a portion of an attic? curls00 Building & Construction 22 10-27-2008 10:41 AM
Insulation over Attic Walkway BigJimmy Building & Construction 4 06-23-2008 03:13 AM
Do I Need Attic Insulation? Carbo HVAC 9 09-16-2005 12:28 AM
