Is This Acceptable? Pics - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-14-2013, 07:26 PM   #1
Rewards Points: 137
Is this acceptable? Pics
I ordered moulding from a lumber yard rather then HD so I would get quality. It came primed and I just sprayed it with a Graco Truecoat sprayer (highly recommend) and used SW Emerald semi gloss. I sprayed the mouldings so they would be nice and smooth. After spraying them you can see every spot where boards were jointed together.
I am posting some pics to see if I am over reacting or not. Let me know what you think.
Troy32 is offline   Reply With Quote
Old 08-14-2013, 07:27 PM   #2
Rewards Points: 137
Pic 2
Old 08-14-2013, 07:28 PM   #3
Rewards Points: 137
Pic 3
Old 08-14-2013, 07:57 PM   #4
Rewards Points: 712
It will be just fine because eventually everyone's house will look like that. Think of it this way; you were one of the first in the decades to come to use joined lumber rather than warped lumber.
Old 08-14-2013, 07:59 PM   #5
Rewards Points: 1,016
Unacceptable. IMHO.
____________
Vince
Old 08-14-2013, 08:16 PM   #6
Rewards Points: 137
Jointed lumber has been used for at least 20 years that I know of. I have never seen it telescope like this. This was not cheap moulding. They tried to sell me cheaper 'house brand' moulding.
Old 08-14-2013, 08:54 PM   #7
DIY staff
Rewards Points: 7,174
That's rather extreme---Is there unusually high humidity where you are working? I've only seen that after a flood-----
Old 08-14-2013, 09:14 PM   #8
Rewards Points: 137
No high humidity. They delivered it and I brought it into the house. I brought it outside on a sunny day to spray it and right back inside an hour later to finish drying.
All of the moulding in the house from the previous owner looks great. I feel this moulding will look terrible with noticeable lines every foot or so.
Old 08-14-2013, 09:16 PM   #9
Rewards Points: 137
I just got back from HD and their moulding is also finger jointed but it is almost impossible to see the joints. The moulding I have you can actually feel the joints when you rub your hand over it.
Old 08-14-2013, 09:27 PM   #10
DIY staff
The lumber yard must have a humid shack --that is not normal --I would expect a customer to pitch a fit if I installed that---
Old 08-14-2013, 10:21 PM   #11
Rewards Points: 137
I am going to speak to the lumber yard tomorrow. Would it be reasonable for them to say it was my responsibility to sand the joints smooth?
Old 08-14-2013, 11:19 PM   #12
Old School
Willie T's Avatar
Probably what they will say.
Willie T
Old 08-15-2013, 02:25 AM   #13
paper hanger and painter
chrisn's Avatar
Rewards Points: 232
I am certain you would not have installed it without sanding it first
Even still that kind of crap is not acceptable, IMO
Old 08-15-2013, 07:54 AM   #14
Rewards Points: 472
if you could feel the joint's , than you should have sanded the joint's down, just paint will not make them invisable , i guess you may have to sand down now the painted board's?? good luck
del schisler is offline   Reply With Quote
Old 08-15-2013, 08:13 AM   #15
kwikfishron's Avatar
Rewards Points: 186
FJ stock is usually pretty clean, you certainly shouldn't have to sand all of the detail.
Not sure why OP painted it instead of just returning it though.
kwikfishron is offline   Reply With Quote
UF Wire Acceptable for Aboveground Use smata67 Electrical 8 03-27-2013 07:28 PM
Finishing basement with pics badbuz Building & Construction 4 02-24-2010 10:31 PM
The award for the dampest, smelliest basement closet goes to...Pics enclosed. TjbDIY Building & Construction 1 08-28-2009 04:59 PM
Utility pole transformer replacement (pics) - Not quite DIY ScottR Electrical 22 06-30-2009 10:16 PM
My subfloor repair project with pics purplewg Flooring 3 06-08-2009 07:38 AM
