-   -   Is this acceptable? Pics (http://www.diychatroom.com/f2/acceptable-pics-185280/)
Troy32 08-14-2013 06:26 PM
1 Attachment(s)
I ordered moulding from a lumber yard rather then HD so I would get quality. It came primed and I just sprayed it with a Graco Truecoat sprayer (highly recommend) and used SW Emerald semi gloss. I sprayed the mouldings so they would be nice and smooth. After spraying them you can see every spot where boards were jointed together.
I am posting some pics to see if I am over reacting or not. Let me know what you think.
Troy32 08-14-2013 06:27 PM
1 Attachment(s)
Pic 2
Troy32 08-14-2013 06:28 PM
1 Attachment(s)
Pic 3
SeniorSitizen 08-14-2013 06:57 PM
It will be just fine because eventually everyone's house will look like that. Think of it this way; you were one of the first in the decades to come to use joined lumber rather than warped lumber.
vsheetz 08-14-2013 06:59 PM
Unacceptable. IMHO.
Troy32 08-14-2013 07:16 PM
Jointed lumber has been used for at least 20 years that I know of. I have never seen it telescope like this. This was not cheap moulding. They tried to sell me cheaper 'house brand' moulding.
oh'mike 08-14-2013 07:54 PM
That's rather extreme---Is there unusually high humidity where you are working? I've only seen that after a flood-----
Troy32 08-14-2013 08:14 PM
No high humidity. They delivered it and I brought it into the house. I brought it outside on a sunny day to spray it and right back inside an hour later to finish drying.
All of the moulding in the house from the previous owner looks great. I feel this moulding will look terrible with noticeable lines every foot or so.
Troy32 08-14-2013 08:16 PM
I just got back from HD and their moulding is also finger jointed but it is almost impossible to see the joints. The moulding I have you can actually feel the joints when you rub your hand over it.
oh'mike 08-14-2013 08:27 PM
The lumber yard must have a humid shack --that is not normal --I would expect a customer to pitch a fit if I installed that---
Troy32 08-14-2013 09:21 PM
I am going to speak to the lumber yard tomorrow. Would it be reasonable for them to say it was my responsibility to sand the joints smooth?
Willie T 08-14-2013 10:19 PM
Probably what they will say.
chrisn 08-15-2013 01:25 AM
I am certain you would not have installed it without sanding it first:whistling2:
Even still that kind of crap is not acceptable, IMO
del schisler 08-15-2013 06:54 AM
if you could feel the joint's , than you should have sanded the joint's down, just paint will not make them invisable , i guess you may have to sand down now the painted board's?? good luck
kwikfishron 08-15-2013 07:13 AM
199 Attachment(s)
FJ stock is usually pretty clean, you certainly shouldn't have to sand all of the detail.
Not sure why OP painted it instead of just returning it though.
