AC Window Units - To Leak Or Not To Leak. - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-10-2011, 11:07 PM   #1
Post
AC window units - to leak or not to leak.
I have 2 AC window units. One in my son's and one in my daughter's room. Neither one of them leak water, ever. Is this a problem? They do not apperar to be leaking into the house anywhere. They both work fine.
wayneles081 is offline   Reply With Quote
Old 08-11-2011, 10:10 AM   #2
Rewards Points: 5,336
I hate when that happens. Everything works as it should, no issues what so ever.
Mt roof doesn't leak, maybe I should go on a roofing forum and ask if this is okay!
You might want to lower the dosage a bit.
Ron
B. Franklin 1759
Old 08-11-2011, 10:27 AM   #3
Wow, tough crowd.
I have 4 window units in my house. One leaks condensate like a faucet all the time. One does it some of the time. The other two only drip on occasion.
It seems to be related to the a/c unit humidity in the air, how long the compressor runs etc.
I wouldn't worry if it's not backing up into the house or elsewhere. It probably doesn't generate that much condensate.
Bill
Billbeas is offline   Reply With Quote
The Following User Says Thank You to Billbeas For This Useful Post:
wayneles081 (08-11-2011)
Old 08-11-2011, 10:34 AM   #4
forget you my friend.
Old 08-11-2011, 10:37 AM   #5
Originally Posted by Billbeas View Post
Wow, tough crowd.
Bill
If yours is leaking, either the tray drains are clogged or the A/C is not tilted to the exterior so it can drain.
I'm now off to the automotive forum, so I can let them know the car runs fine.
Ron
B. Franklin 1759
Old 08-11-2011, 10:41 AM   #6
Maybe lower it more then a little.
Ron
B. Franklin 1759
Old 08-11-2011, 10:51 AM   #7
A Little Of Everything
Rewards Points: 1,364
No need to always be a caustic smart a$$...
It's better to ask and find out that you're doing it right, than to not ask and find out the hard way that you're doing it wrong.
Air Conditioners almost always produce condensation. The question is one of where that condensation goes. I learned the hard way - way back when - to be very careful of the way window units are tilted.
DrHicks is offline   Reply With Quote
Old 08-11-2011, 12:26 PM   #8
Learn to follow the conversation.
I informed Billbeas about his A/C issues and how to fix them, sans comment on that.
I did comment on, "wow, tough crowd" and the OP's, "post for no reason" because, well, it had no purpose. He had no issue. A lot of spare time, but no issue. If he comes back with an issue, I will help him.
Unless he's building a house on stacked 20 foot 6x6's on the side of a mountain.
I'm off to the Audio forum....
Ron
B. Franklin 1759
Old 08-11-2011, 12:48 PM   #9
You seem to be spending an awful lot of time and energy on his non-issue.
By the way, my Jeep is running just fine, thank you!
Old 08-11-2011, 12:54 PM   #10
As long as the ankle bracelet is on, I have plenty of time.
I think the Jeep comment is a little caustic.
Have a good day, Doc.
Ron
B. Franklin 1759
Old 08-11-2011, 01:01 PM   #11
You too.
Old 08-11-2011, 07:10 PM   #12
Rewards Points: 282
modern window units splash the condensate onto the coils to improve cooling and efficiency.
jcrack_corn is offline   Reply With Quote
Old 08-11-2011, 09:04 PM   #13
My air conditioners are just fine they are leaking from the drain holes as they should.
I was just providing examples.
As far as the caustic comments, if you don't like the topic ignore it. Think of all the time you've spent commenting on a non issue.
Old 08-11-2011, 09:52 PM   #14
Ron
B. Franklin 1759
Old 08-12-2011, 08:09 AM   #15
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
why not just answer the question?
your window a/c is designed to hold the condensate water in the bottom of the unit, when your unit runs the fan blade will fling the water over the condenser coil cooling it down and improving energy efficiency. Depending on humidity levels and how much it runs it may never leak out the back side.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
The Following 2 Users Say Thank You to hardwareman For This Useful Post:
operagost (08-12-2011), Ron6519 (08-12-2011)
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 12:47 PM
Stationery / Transom / Picture window ??? CoconutPete General DIY Discussions 7 02-04-2011 09:36 AM
Bathroom window issues? Mantaray14 Remodeling 11 12-04-2009 07:40 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 10:47 AM
Cathedral Ceiling - mystery roof leak kamadus Roofing/Siding 4 05-06-2008 01:18 PM
