AC Power Gate Opener - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-24-2012, 01:41 AM   #1
Send a message via Skype™ to kutsyy
AC power gate opener
I am looking at installing iron gates with an automatic gate opener. The gate is about 200 feet from the nearest power. So to run 110 volts to it require 200 feet of conduit 18" underground. On other hand low voltage wire can be run much easier.
Does anyone have an experience with AC/low voltage automatic gate openers? Let say http://www.mightymule.com/gate-openers-fm502.htm as an example. Local automatic gate company representative was negative about it, but he is a sales person.
Any recommendation/suggestions will be appreciated.
Thanks,
Vadim
kutsyy is offline   Reply With Quote
Old 05-24-2012, 07:20 AM   #2
Look into solar powered gate electronics. No need make long cable runs.
Old 05-24-2012, 09:55 AM   #3
I also want to add intercom with video camera, and it is too far for wireless, so I need to run low voltage wire anyway. Anyway, it doesn't change my question, how reliable are low voltage gate operators (either they are powered by transformer or solar)?
Old 05-24-2012, 01:06 PM   #4
To save money on long runs of copper go to higher voltages and lower currents. A default value for power for this device could be 1 hp. Solar will give you about 160w per sq. meter of panel. I doubt that any manuf. of consumer equip. will give you MTBF numbers for their products.
TV power bridge into existing outlet and protected by an external surge protector andytran73 Electrical 4 12-14-2011 09:00 AM
Craftsman 1/2hp Garage Door Opener No Power DIYfer General DIY Discussions 4 09-11-2011 10:02 AM
Wring for Lincoln Power Mig Welder vstoyko Electrical 17 01-15-2009 07:15 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 10:58 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
