-   -   Absolutely can not remove wallpaper paste (http://www.diychatroom.com/f2/absolutely-can-not-remove-wallpaper-paste-19163/)
Corcoran1 03-29-2008 02:42 AM
I have some wallpaper I removed from the bedroom wall. It had been put on over wall liner. The liner came off with the paper on 2 walls and remained on the other 2. The problem is that on these walls I can not get the paste off the wall for the life of me. I have tried EVERYTHING. It's very hard like dried super glue and water/liquid does nothing to it at all. Can I just put more paintable wall liner over it or can I just paint over it? Even sanding hasn't done much good at all. I used 80 grit or whatever and it did nothing. This stuff won't budge. I've had no problem getting the paste off all the other walls in the other rooms. Any advice?
slickshift 03-29-2008 06:51 AM
Seal it with Zinnser's Gardz
This will seal in the paste, and turn any boogers hard so they can be chipped/knocked/scraped off
Then sand to smooth
If, at this point, you need to smooth out the wall, you can skim some joint compound over the areas with putty/taping knives
Sand any repairs areas smooth and prime them (regular primer is OK, or Gardz if you still have some left)
rubicon789 03-29-2008 08:02 AM
Another Idea for covering it would be to apply Venetian Plaster over it. I would think you have to get most of the fuzzy stuff off first though.
