Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 08-13-2007, 05:51 PM   #1
Above Ground Swimming Pool Filter Tank
Does anyone know of a material or a way to seal a hair line crack in an above ground pool filter tank. I was told there wasn't a way but that doesn't make sense. The pressure in the tank is usually about 17psi. I have tried a vinyl repair and it just blows out. Any help is appreciated. Thanks, Tom
twaters12 is offline   Reply With Quote
Old 08-13-2007, 07:40 PM   #2
Agent 000
SecretSquirrel's Avatar
See if one of these products will fit the bill;
http://jbweld.net/products/index.php
SecretSquirrel is offline   Reply With Quote
Old 08-13-2007, 08:06 PM   #3
Eibwen
I have never tried it, but since the filter tank is normally fiberglass, try a fiberglass repair kit from the inside of the tank, let it try well, and see if it holds.
Sammy is offline   Reply With Quote
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Swimming Pool Water pilotandy72 General Discussion 4 07-31-2007 11:04 AM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
Swimming Pool Light Broc Electrical 1 08-15-2006 03:23 PM
deck around above ground swimming pool notveryinclined Building & Construction 1 07-13-2006 10:47 PM
