Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 04-17-2009, 03:53 PM   #1
above ground pool HELP
i just purchased an above ground pool 20 ft * 4 ft soft side....
i am putting it on a large concrete slab i had poured a few years ago
do i still need to put sand under the pool?
jnmartindale is offline   Reply With Quote
Old 04-18-2009, 08:53 PM   #2
Master General ReEngineer
Bondo's Avatar
Ayuh,... It would probably be Better for the pool to cushion it with a layer of sand...
Old 04-24-2009, 05:57 PM   #3
I installed ours on pea gravel. I laid some old material and carpet that I had hanging around and put a tarp over that.
I think the rough surface of the concrete would soon put holes in the bottom of your pool.
tranman is offline   Reply With Quote
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Above Ground Pool Privacy Fence hammermonkey Building & Construction 4 02-25-2009 05:27 PM
Slab Ground pool inspection alexromu Electrical 6 08-06-2008 08:01 AM
Above Ground Swimming Pool Filter Tank twaters12 General Discussion 2 08-13-2007 08:06 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
