-   General Discussion (http://www.diychatroom.com/f2/)
-   -   above ground pool HELP (http://www.diychatroom.com/f2/above-ground-pool-help-42655/)
jnmartindale 04-17-2009 03:53 PM
i just purchased an above ground pool 20 ft * 4 ft soft side....
i am putting it on a large concrete slab i had poured a few years ago
do i still need to put sand under the pool?:huh:
Bondo 04-18-2009 08:53 PM
Ayuh,... It would probably be Better for the pool to cushion it with a layer of sand...
tranman 04-24-2009 05:57 PM
I installed ours on pea gravel. I laid some old material and carpet that I had hanging around and put a tarp over that.
I think the rough surface of the concrete would soon put holes in the bottom of your pool.
