I have an above ground pool with a deck all the way around it. Every year when I get it covered, the inflatable pillows always deflate and I end up with a ton of water on the cover, then the pump winds up ripping the cover. The liner recently ripped and I am not gonna replace it until next year, but I still need to cover it for the winter. I was thinking of covering it as usual, but first I was going to lay pvc pipes every 5 or so feet then lay the cover on top of that so it doesn't sag. Do you guys have any other suggestions. I was also thinking about building a structure out of pvc, kind of like a table, that I would put on the floor of the pool and that would hold up the cover. Any help is greatly appreciated. Thanks
My dad used to use empty (and cleaned) plastic gallon milk jugs or something such as that and floated them on the water to support his cover. For that to work the water lever would have to be quite high. I know some people that lower the water level in the winter freeze. It would not work for them.
the pvc pipes will sag as they cross the pool. The will not support themselves let along and weight from water on the cover.
something along the lines of your table in the pool:
a single tent pole type structure for the center of the pool. You would have to put a large flat plate on the bottom end so it doesn't pierce the bottom of the pool and something such as a large salad bowl shaped piece (upside down) for the top so it won't pierce the top.
I had the same problem 5 years ago and I purchase a reel, I forgot the exact "arrangement" of the name but you can find it using these words on the net above-ground rugged mesh winter pool cover - pool size: 12' x 20' oval- arctic armor or you can just click the link
However, I'm not sure if it fits all sizes of aboveground swimming pool
I'd be more inclined to use a shop vac to suck the water off. I think you'd be less likely to rip the liner.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
