Above Ground Pool Advice Needed. - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-29-2009, 10:26 AM   #1
Above Ground Pool Advice needed.
I just got a 10 x 30 Intex above ground pool. After filling it up, it is unlevel about 1 1/2 inches on one end.
Will this be a problem or should I drain it and level it out?
Thank you for any feedback.
TTran is offline   Reply With Quote
Old 04-30-2009, 06:20 AM   #2
That's a lot of water to throw out. There is no simple way to correct that without a lot of work. I would be inclined to leave it as is, but I am not a pool expert.
Old 04-30-2009, 11:18 AM   #3
Fixer-'til-broker
DIYtestdummy's Avatar
Rewards Points: 262
Leave it and remember to level it out next time you fill it. Otherwise, find some way to use or capture the water.
I had an 8x8' and ended up truckin' in beach sand. Made a crater, which made it deeper inside and made it easier to level when full.
"Aw! Why does everything that only happens to stupid people happens to me?" - Homer J. Simpson
DIYtestdummy is offline   Reply With Quote
Replacing cord on a 1.5 hp above ground pool pump LeeAmes Electrical 23 04-20-2009 01:45 PM
Advice needed. Complete Furnace & duct replacement - asbestos ductwrap (crawl space) vestaviascott HVAC 11 03-10-2009 05:40 PM
Above Ground Pool Privacy Fence hammermonkey Building & Construction 4 02-25-2009 04:27 PM
To ground or not to ground, that is the question cartalker Electrical 8 10-18-2008 10:12 AM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 02:59 AM
