8.5 Craftmen Roto Tiller - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-21-2009, 07:30 PM   #1
8.5 craftmen roto tiller
I fill the gas tank and gas runs right out the muffler. Can anyone help?
Thank you, kdan
kdan is offline   Reply With Quote
Old 03-22-2009, 08:15 AM   #2
Rewards Points: 5,336
Take it to a service center and let them fix it.
Ron
Old 03-22-2009, 04:55 PM   #3
Unhappy
gas proplem on 8.5 craftsmen tiller
That does not sound like a diy respnse
Old 03-22-2009, 05:50 PM   #4
What else has been done to this tiller?. I don't have one but basically you are saying fuel is flowing freely through the carb and out the exhaust and it's not even running?....while you are fillling it.... Makes no sense.
Are you sure it is coming out the muffller or do you have a fuel line leak in the area of the muffler.
If it is running you are blowing unburned fuel right through so if that were happening you have a carb running fuel like a wide open tap?
Give us a bit more info
Chemist1961 is offline   Reply With Quote
Old 03-22-2009, 07:12 PM   #5
Safe, Most of the Time!!
brokenknee's Avatar
It is possible that the needle is not seating. Take the carb apart and put in a rebuild kit. Make sure you replace the needle and seat. Spray carb cleaner in every little hole you can find. Do not try to clean the needle with carb cleaner; most have a neoprene end that does not take kindly to carb cleaner.
When you take out the idle adjustment screws make a note on how many turns out from bottoming out they are. I believe most low idle screws you start one and a half turns out. I can't remember the high idle screw off hand.
Also check what Chemist said before tearing apart the carb.
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Old 03-22-2009, 07:25 PM   #6
Tom Struble's Avatar
Rewards Points: 2,002
float could be full of fuel dismantle the carb pull the float and shake it if it feels heavy or liquid sloshes around replace it along with the needle and gaskets if that dont work you need a new carb
Tom Struble is offline   Reply With Quote
Old 03-22-2009, 07:53 PM   #7
brokenknee's Avatar
Don't forget to change your oil. If gas is leaking out of the muffler it is also getting into your oil.
Old 03-23-2009, 03:41 PM   #8
Wink
Tiller up And running
Thanks fellows! The carb repair kit was a fix. I did not intend to miss Lead you but the gas was coming out of the carb through the air cleaner.It was some time ago and i didn't think to clearly about, shoud have went & rechecked Thanks again kdan
replacing magneto on tiller? NateHanson Automotive Repairs 9 02-08-2009 07:59 PM
Looking for a Roto Zip MillerClemsonHD Tools 10 12-31-2007 09:09 AM
