3 Tab Shingles - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-10-2006, 10:28 PM   #1
3 Tab Shingles
Im Going To Install Timberline 30 Shingles.can I Use Just Reguler 3 Tab Shingles For My Starter Strip And For My Ridge Hip?just Cant See Using Expensive Shingles Just To Cut Them Up Or Would It Be Better To Buy All The Same Shingles?
glassman is offline   Reply With Quote
Old 10-11-2006, 04:21 AM   #2
747
registered
747's Avatar
Rewards Points: 534
i guess if you cut the three tabs off of them and they match the color.
747 is offline   Reply With Quote
Old 10-11-2006, 05:49 AM   #3
World famous jerk.
It's a common cost saving technique, but in reality when you consider the labor, you're not saving much. Sometimes the color match isn't good either, but it can be hard to tell if you only have ridge. If you have hips to cap, the color difference can be a bigger deal.
mdshunk is offline   Reply With Quote
Old 10-11-2006, 10:34 AM   #4
renovations
For starter, I use the elk starter strip, cheap, easy, fast, very functional. I've never had a problem with matching the colour and often use three tab for ridge/hip. Cut the tabs at an angle so the covered (hidden) part of the shingle is narrower than the exposed and you will have a really tight looking ridge.
Bonus is offline   Reply With Quote
Old 10-11-2006, 03:17 PM   #5
General Contractor
They make ridge cap shingles to match your shingles.
Hammatime is offline   Reply With Quote
Shingles per bundle redline Roofing/Siding 11 09-11-2011 10:41 PM
cutting shingles to install gutters Chicago Bill General DIY Discussions 2 02-27-2009 05:42 AM
Masonry Asbestos Shingles, how do I know? ourzoo Building & Construction 8 08-27-2007 08:57 AM
bending shingles farrington135 Roofing/Siding 2 06-09-2007 10:40 AM
replace tar & gravel roof with shingles & torch down rt1035 Roofing/Siding 4 12-17-2005 05:39 PM
