-   -   2x4 Basics Workbench with CASTERS ??? (http://www.diychatroom.com/f2/2x4-basics-workbench-casters-172503/)
CaptainMarvel 02-20-2013 04:32 PM
My (nearly completed) 2x4 Basics based workbench/assembly table is 8' x 3.5' with 3/4" MDF shelves/top - so, as you can imagine, it's pretty heavy. The 2x4 Basics legs seem pretty sturdy, but I just wonder each leg's bottom "shelf" will support attaching casters to it.
Perhaps adding an additional piece of wood on each leg - between each shelf - as a kind of brace might lend to additional support ?? .... I dunno.
I'm wondering whether anyone here has tried to put casters on the bottom of their 2x4 Basics bench or assembly table?
If so, might you be able to put up a photo or two to show how you did it?
THANKS !!!
TOM
joecaption 02-20-2013 05:13 PM
Think about it, how would anyone know without a picture?
I want my work brench to sit in one spot and be rock solid.
CaptainMarvel 02-20-2013 05:20 PM
Sure ... But when one's workshop is also one's two-car garage, the option to be able to move it to the side
(if necessary) can be handy. Hence, my research/question.
:smartass:
Bondo 02-20-2013 05:49 PM
:smartass:
Ayuh,... just put another 2x horazonal 'tween the legs, boxin' 'em for strength,...
Then screw the caster to Them...
If it wobbles, put some corner braces in...
bbo 02-20-2013 07:37 PM
I'm with bondo.
for mine, I was able to do the cheap route.
Wifey did not like the kitchen island in our house. I pulled it out, put some casters on the bottom, now I have a moveable workbench. ( make sure to get at least two of the casters with brakes. )
CaptainMarvel 02-28-2013 01:31 PM
Right ... but what I was asking/wondering is whether anyone has successfully added casters to their 2x4 Basics workbench - and, if so, how has it been working out and might there be some pics to share.
I AM going to give bondo's suggestion a try - perhaps as early as this weekend. Mine is a hefty 3.5' x 8' assembly table/workbench - so it's going to take some assistance from a buddy of mine to help me safely turn the bench on it's side (likely onto some foam insulation) and back up once the casters are installed.
When I do this, I will be sure to take pics of the process and report on the result.
Bondo 02-28-2013 02:12 PM
Ayuh,... Make sure ya take into account the height of the legs, 'n casters,...
It'd be an ashame to build it, 'n find ya need a ladder to use it...
TheBobmanNH 02-28-2013 02:23 PM
I built a workbench and put casters on it. Made sure they were locking casters and nice and solid so it wouldn't wobble when I didn't want it to. WOrks out well.
CaptainMarvel 02-28-2013 02:24 PM
:laughing: . . . I Know, Right?
For visual reference sake, my bench (basically) resembles this ...
http://images.lowes.com/product/conv...39010381lg.jpg
Since I cannot find any pics depicting the construction process, there is basically some leftover space on each "shelf" of the 2x4 Basics workbench legs - with each 2x4 (or, in my case for the bottom shelf/bracing, 2x6's) cornering on each leg shelf.
The following pic kind of depicts the basic concept pretty well . . .
http://ecx.images-amazon.com/images/I/41KOpjveQ8L.jpg
So, what I was thinking I would do is miter 4x4's to fit within the space - having each piece log enough to also serve as an additional support brace between the first and middle shelves - make sense? Going to have to drill a few additional holes into the bottom shelves of the 2x4 Basics resin legs - but I'm thinking it will work out. Just need to figure out which screws to use.
CaptainMarvel 02-28-2013 02:25 PM
Is/Was your workbench based on the 2x4 Basics workbench legs?
boukord 03-29-2014 09:16 AM
I've ordered this and plan to build it without a full middle shelf- maybe just bracing on 3 sides and will add casters. I saw a post that describes scabbing extra 2x4 and mounting casters on lower 2x4. Probably fine, but then the load to the legs is entirely lateral and I feel that the load should be directed up, so I will try and have the caster plate directly under both sides of the plastic leg: I'm going to scab a short 2x4 to either the front or side lower 2x4, then to fill the void which looks like maybe 1/2" between the wood and the bottom of the leg with a thin 4x4 or whatever, so that when I mount the caster, its base plate will catch both sides of the plastic leg. I like to plan, not so much to build but when I get this done someday I'll send a pic.
ToolSeeker 03-29-2014 09:30 AM
What the heck are you calling a 2x4basics workbench? I have seen probably 50 different workbenches made out of 2x4s.
r0ckstarr 03-29-2014 03:01 PM
http://www.menards.com/main/building...466-c-9442.htm
ToolSeeker 03-29-2014 03:22 PM
So your paying $70 for four legs you could also make out of 2x4?
Peter Kay 11-25-2015 09:56 AM
Mounting casters on a workbench when using 2x4 construction is not sturdy enough because pine 2x4 is soft. I suggest Bench Dog Caster brackets which bolt through 2 2x4s and hold a threaded pin caster securely. They are sold on Amazon and they do not protrude to trip on.
