2nd Attempt Gate. - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-12-2012, 12:43 AM   #1
I love my new front yard!
Telfair's Avatar
Rewards Points: 158
2nd attempt gate.
Ok so here the link to my 1st gate.
My gate has become very tweaked
& I had a couple of issues with it so now we re-did it & It seems much more solid, than the last one, but now I'm looking for ideas on what to do with it?
I do have a dog & want to keep him in the yard & also keep strange dogs out of my yard..
So I'm looking for ideas...?
2nd attempt gate.-img_3480.jpg   2nd attempt gate.-img_3487.jpg   2nd attempt gate.-img_3485.jpg
Telfair is offline   Reply With Quote
Old 11-12-2012, 05:07 AM   #2
DIY staff
Rewards Points: 7,174
That looks much better---the gate is kind of tight and may bind when it swells in the rain or sags a bit---
Gates need to be 'loose on the hole'---about 3/4" narrower than the opening.
The butt joints at the corners are a rather weak type of joint for a heavy gate-----adding metal L bracket to the corners will stiffen that right up.
Looking good---gates are a challenge to build---that one looks like a winner----just add some metal Ls to the corners and it will serve you well.
oh'mike is online now   Reply With Quote
Old 11-12-2012, 08:10 AM   #3
AHH, SPANS!!!
Rewards Points: 1,166
As Oh Mike mentioned, L metal brackets at the corners would be great for the gate... you can find grk fasteners at box stores and they sell a heavy duty 1 1/2 screw that I've used to put the L hangers on gates/deck access doors etc...
hand drive is offline   Reply With Quote
Old 11-12-2012, 08:35 AM   #4
Rewards Points: 12,824
Outside frame still built wrong.
You have left the end grain exposed.
To piece should have ran all the way across the whole length.
The end grain is where the wood is going to soak up the most water and rot, and expand more.
Without it being narrower there's no room for the door to swing.
Old 11-18-2012, 05:21 PM   #5
Telfair's Avatar
Rewards Points: 158
Some finishing touches to the gate to keep the dog in & others out.
I like the natural wood theme I was able to keep.
The Following 2 Users Say Thank You to Telfair For This Useful Post:
mae-ling (11-18-2012), oh'mike (11-18-2012)
Old 11-19-2012, 10:54 PM   #6
Telfair's Avatar
Rewards Points: 158
Threw a ball this evening & it seems the dog dove right through the decrotive wood, So now, I've gotta come up with another plan?
I'm thinking Chicken wire on the back side?
Looking for simple Gate ideas Telfair Building & Construction 22 06-05-2012 05:05 PM
Need to ID Gate Valve (Please Help) MikeGV Plumbing 3 10-04-2010 12:02 PM
Gate Design Question rocknroll99 Building & Construction 5 04-13-2010 08:46 AM
Driveway Gate Construction Questions KP Texan Building & Construction 3 07-30-2009 09:45 PM
