240 Baseboard Heaters Dont Work Till Room Is Warm? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-09-2011, 07:43 PM   #1
240 baseboard heaters dont work till room is warm?
I'm having some issues with these Dimplex baseboard heaters. I installed them in the fall when it was warmer, everything was working fine. I recently went to the cabin go to turn them on and nothing. Temp is now below freezing. I warmed the cabin up with the wood stove and they came on after a few hrs? They are being controlled by a double pole thermostat.
Any idea even where to start??
jeffo8 is offline   Reply With Quote
Old 12-09-2011, 11:33 PM   #2
Rewards Points: 1,092
Contact the company yet? It may have something to do w/ the temp being below the temp set point range.
Old 12-10-2011, 06:19 AM   #3
Check wiring connections for tightness. Tighten wire nuts, if wires are not twisted together, do it. Check screws on breakers, hot and neitral.
Thermostats should be on whenever the temp is below the setting. Check that they are indeed on with an ohmeter(power off!!)
Old 12-10-2011, 08:12 AM   #4
Yeah I'll have to wait till monday to contact Dimplex. Never had any test
Equp with me. Thought of the loose connection issue but ruled that out when
The first heater came on. What's even more odd is the came on at different
times. As in order of which room warmed up first. Heaters should come on regardless
the inside temp unless your at your set point. Even went at far as swapping out the breaker.
Old 12-13-2011, 09:12 AM   #5
follow up
So it appears some of the thermal cutouts were filled with water and not glycol. So if your building drops below freezing well guess what your baseboards aren't coming on till they're warmed up. Dimplex are sending me new cutouts. Thanks for responses though. Now u know.
J
Old 12-13-2011, 11:26 AM   #6
jschaben
Rewards Points: 502
J
what a thing to try to troubleshoot
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Electric baseboard heaters ? ants1929 HVAC 11 03-11-2011 08:23 AM
Remove a big baseboard and add 2 smaller ones Metallo HVAC 6 01-29-2011 07:07 PM
how to wire up electrical baseboard heaters mmd21 Electrical 13 12-05-2008 08:11 AM
switch gear room pipe work goose134 Project Showcase 6 09-17-2008 12:29 AM
Removing Baseboard Electric Heaters gieriscm Electrical 12 11-12-2007 04:59 PM
