2 Questions Need Advice??? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-29-2008, 10:46 PM   #1
Question
2 Questions need advice???
First: Is Aluminum siding a good insulator? Good enough to not worry about "non insulated" walls under it?
Second: Does this sound like a good idea for prepping for a new roof?
Its cold here now. About 20 degrees F. Can't do a roof now. Have to wait for the Spring. I have 3 leaks that I can see now. I will get them patched up. Then I have drop down ceilings upstairs in 3 rooms. They all have molded ceilings above them. I want to rip down all those ceilings. Then I have plastered walls with lath. And it looks like their is mold on the plaster. So I want to rip down all the plaster in those rooms also. Then throw all that crap in a dumpster and ship it out of here. Then Spring will come and I'll get the roof done.
I'm looking at some semi-open walls and no ceilings in three rooms for a few months. This shouldn't be a big deal right?
Its a two story house. We currently live on the main level. We don't even go upstairs really. We have a door that is closing off the entrance to the stairs which leads to upstairs.
What do you guys think?
Tdoggy187 is offline   Reply With Quote
Old 01-30-2008, 11:18 AM   #2
What is your latitude and state/location? If there are no water pipes that might freeze upstairs, you can just seal off the upstairs for the winter.
CalMvl is offline   Reply With Quote
Old 01-30-2008, 11:31 PM   #3
Question
new York
I'm in upstate New York. It is very cold up here. Their are no water pipes that are upstairs.
Adding a subpanel to a sub-panel and other questions CardinalPilot Electrical 14 03-30-2011 02:23 PM
Aluminum-wired house, questions LMH Electrical 2 05-24-2009 03:06 AM
I need advice on a flat roof Krissy Roofing/Siding 10 12-27-2007 01:55 PM
tiling questions - in middle of install mwill Flooring 8 12-11-2007 05:06 PM
some questions on masonry/cement/concrete (general q's) joeyboy Building & Construction 20 06-25-2007 08:53 PM
