2 Pole 20 Amp Breaker Question - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-12-2011, 05:02 PM   #1
2 pole 20 amp breaker question
Dose that compine and equal 40 amps?
I added a 240 volt plug for a welder. The welder was a 20 amp 230 volt.
I used a 2 pole 20 amp breaker. Did i put 40 amps on the welder and fry it. the welder isnt working but has not been used in over a year it my have a problem.
I ran 10 gauge wire. 2 hots and a neutral. I have power.
Kenny101 is offline   Reply With Quote
Old 06-12-2011, 05:26 PM   #2
Rewards Points: 1,016
Not 40a, still just 20a. What kind of welder - what is the maker and model of the welder, is 20a enough? While it should ok at a lower amp settings on the welder, maybe not on higher settings. But it should still turn on - does not draw large power till you strike an arc. #10 wire you can use a 30a breaker. That's what I have my Millermatic 180 MIG running on. You have power you commented - 240v across the two hots, and 120v each hot to nuetral?
____________
Vince
Old 06-12-2011, 05:34 PM   #3
Thanks... Ya i have 120 at each hot. It must be the welder. Its just a small lincoln electric. Its my buddies. we both assumed it was the welder im just double checking.
Old 06-12-2011, 07:20 PM   #4
Rewards Points: 5,336
It's probably the wiring that's the issue. The amperage size of the breaker is not what goes into the elecrical device, it's the cap at which the breaker shuts off if the current exceeds the breaker.
When you wire a breaker for a device, you see what amperage the device calls for and install that size breaker. A 10 guage wire would call for a 30 amp breaker, but that doesn't mean the welder can run on that amperage.
The plate on the welder, or the manual or the manufacturers web site will tell you the amperage requirements.
Unlikely a long layoff caused the welders problem. It's usually operator error.
Ron
B. Franklin 1759
Old 06-12-2011, 08:07 PM   #5
joed's Avatar
Rewards Points: 12,854
You have 120 at each hot but what do you have hot to hot. You should have 240 volts. It is possible in some panels to install the breaker so that you don't get 240 but still get 120 on each hot.
Also you need to use a full size 240 volt breaker and not a mini or tandem breaker.
Old 06-12-2011, 08:52 PM   #6
Take a picture of the breaker and post it.
Ron
B. Franklin 1759
Old 06-12-2011, 10:01 PM   #7
I was using the wrong breaker.. I was using a 20 amp tandum breaker.I replaced it with two 20 amps.
Thanks for the help.
Old 06-12-2011, 10:04 PM   #8
Electrical Contractor
jbfan's Avatar
Rewards Points: 474
A 240 volt circuit requires a 2 pole breaker, or a handle tie.
2 20 amp breakers are not code compliant.
jbfan is online now   Reply With Quote
Basement improvement / AFCI Breaker Question BiOs2k Electrical 0 02-25-2011 10:32 AM
240 volt breaker question Chet Douglas Electrical 17 02-06-2011 04:56 PM
Heater wiring and breaker size question Tmb9862 Electrical 12 12-26-2009 03:27 PM
Sq D Trillaint Breaker problem jmreynol Electrical 3 04-28-2009 07:06 PM
Knockout Plug and Breaker Question Jack A. Trades Electrical 4 06-14-2008 09:42 AM
