2 Doors Opening Into Each Other. - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-27-2012, 07:57 PM   #1
Rewards Points: 212
2 doors opening into each other.
Sorry no pics. They swing in, are hinged in the corner, and the knobs run into eachother.
My solution is a springy door stop, mounted high, on a two inch block/spacer (so the stop reaches beyond two door knobs).
Kind of would look hokey, but can't think of another way.
Squeakyhinge is offline   Reply With Quote
Old 09-27-2012, 08:18 PM   #2
Rewards Points: 13,296
Install a hindge stop.
Just knock out the pin set the stop in place and tap the pin back in place.
http://www.bing.com/images/search?q=...BD27D8&first=1
Old 09-27-2012, 10:31 PM   #3
Rewards Points: 212
If there's a stop then the doors can't open more than half way. And one is an entrance door. Eek
Old 09-27-2012, 11:12 PM   #4
Depends how much work you want to put in.
What does the interior door open into? if there is room maybe reverse the door so it opens inwards IE remove the casing, door and door jamb, and reverse the whole thing, reinstall casing. You may have to deal with a gap where the casing meets the baseboards. Or possibly replace with a pocket door.
chrisBC is offline   Reply With Quote
Old 09-28-2012, 11:34 AM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 1,130
That is what I was about to suggest....assuming that one door is a closet....
What does the entrance door go to?
ddawg16 is online now   Reply With Quote
Old 09-28-2012, 12:31 PM   #6
Rewards Points: 2,210
Hinge door stop way less work.
https://www.google.ca/search?q=hinge...Dov7qAHNqoG4Cg
mae-ling is offline   Reply With Quote
Old 09-28-2012, 08:53 PM   #7
Rewards Points: 212
The picture is accurate. The door on the right is an exit door; the one on the left is to a stairwell going down so it can't be changed; it won't clear the sloped ceiling.
Old 09-28-2012, 09:04 PM   #8
Not following you, right now the doors can not be opened up more then 90 deg.'s All a hindge stop will do is stop the two doors from opening so far the knobs hit.
mae-ling (09-29-2012)
Old 10-01-2012, 03:48 PM   #9
Mold!! Let's kill it!
Rewards Points: 2,012
Mount a roller stop on one door. It will save the hinge screws and be much cheaper than a new door configuration.
http://absupply.net/don-jo-1486-4-12...per-24382.aspx
Old 10-01-2012, 04:37 PM   #10
i dont know why you want to change it, ive got doors like this in my master bath and i LOVE them. if both doors are open, it stops someone from pushing the exit door open. Added security. I love it. If you want to change it, i agree with maintenance.
firsttimeremode is offline   Reply With Quote
Old 10-02-2012, 09:35 AM   #11
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
I have one of these mounted to the top of one of the doors, it works pretty well.
You have to mark a spot and see if it works to make sure the point you pick does not "slide off" one of the doors when they reach a certain point.
CoconutPete is offline   Reply With Quote
Old 10-02-2012, 09:57 AM   #12
Bombastic Idiot
notmrjohn's Avatar
I dunno what you mean by "exit door." Guess it depends on which room you're in.
But you have a safety issue. One of those doors needs to open away from this side.
If one of the doors is open, it colud prevent other door from opening, trapping some one on other side. It does not matter if there is another exit on other side, it could be blocked as well.
Or scary goblin could be coming up stairs.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Repair or Replace Garage Doors??? jbird0005 Windows and Doors 2 12-10-2011 07:42 AM
Reality check on interior doors recently delivered PatBB Carpentry 8 09-05-2011 06:36 PM
Hang six panel doors upside down; how goofy will this look? -Pics buckybadger Carpentry 16 09-01-2011 02:52 PM
Home Made Closet Doors allen1466 Building & Construction 9 10-25-2007 05:57 PM
