Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-10-2013, 08:42 PM   #16
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
1925 brick Bungalow attic project
Originally Posted by matulch View Post
-pugsy
I re-calculated the room width and got the same results. Both methods give the same answer.
Sorry about that. I thought the picture was a sample from somewhere and not your house.
If this is your house, the numbers are dead on and not looking good at all.
123pugsy is offline   Reply With Quote
Old 01-12-2013, 11:46 AM   #17
If I make the room a general purpose room the average height can drop to 7'
This is what the it would look like.
This option would add 350 sq feet to house I just can't call it a bedroom.
GBR - Not sure what measurements I made before, But I can frame up the window larger to make it up to code.
matulch is offline   Reply With Quote
Old 01-12-2013, 12:12 PM   #18
123pugsy's Avatar
That's a decent sized space.
Old 01-12-2013, 03:55 PM   #19
Moderator
Did you ask your AHJ? Usually the knee walls can be as short as needed, only the code lists minimum per room size.
Gary
Clothes taking longer to dry?
Old 01-18-2013, 10:08 AM   #20
Talked with the local AHJ. He said I could drop the ave height down to 7' and still call it a bed room
He also said I need an R value of 38, so it looks like I need a thick 5.5" layer of spray foam for the room.
I think i will spray 2" on the roof portion that is not part of the room and 5.5" for the part that is part of the room.
Old 01-22-2013, 09:36 PM   #21
Here is my insulation plan
use Demilec Heatlok Soy 200 7.4 R value at 1 inch
spray 5.5 in thick for room and 2 in thick for the rest of attic roof.
I am also thinking about adding fiberglass under the 2in foam section of attic.
Here is what the space is looking like.
What do you think?
Old 01-24-2013, 05:09 PM   #22
Moderator
What did he say about venting the lower attics behind the knee walls?
Gary
Old 01-25-2013, 07:46 AM   #23
Gary ,
We did not talk about it. He told me to make sure to vent the bathroom If i do put one in.
The attic currently does not have any venting so I think keeping it that way with spray foam would be the easiest way.
The Following User Says Thank You to matulch For This Useful Post:
Gary in WA (01-25-2013)
Old 01-26-2013, 10:27 PM   #24
Looking for a little advice on HVAC for the attic space. How do i know if current HVAC system can handle the extra space?
Should I look into a Ductless Mini Split?
Thanks,
Chris
Old 01-27-2013, 12:22 AM   #25
Moderator
Start another thread in the HVAC forum, here; http://www.diychatroom.com/f17/
Gary
Raccoons in the attic electricpete Pest Control 17 05-12-2011 05:02 AM
Attic fan options P550 Roofing 1 08-22-2010 01:47 PM
Attic fan options. P550 Electrical 6 08-22-2010 01:30 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 07:41 AM
Powered Attic Fan question spup345 Roofing 9 06-30-2008 09:10 PM
