12ft Boards In A 6ft Truck Bed - DIY Truck Rack - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 3 Post By r0ckstarr
  • 1 Post By Fix'n it
Old 07-20-2016, 05:03 PM   #1
r0ckstarr's Avatar
Rewards Points: 2,060
12ft boards in a 6ft truck bed - DIY truck rack
I tried the bolt-in truck rack that the local sporting goods store sells. It had too much side to side wobble, and attached by clamping onto the bed rails. It just seemed like it would deform or damage the bed of my truck over time, and I ended up taking it back. I looked at another one at a shop here, but it required drilling through the bed rails to attach it. I don't like the idea of drilling into the body, so I passed on that one.
So, I searched for home made truck rack on google images, got a few ideas, and got started. I wanted something that wasn't permanent, wasn't time consuming to set up, and something I could easily store in a shed without taking up too much room.
First, I thought that if I built a square frame close to the tailgate, I could strap the boards to that, and the other end to the roof of the truck. This is what I came up with.
I built it to sit flush against the floor and sides of the bed.
Once I put a board on top, I hated the idea and figured it would never work, or be very safe.
After rethinking my plan, this is what I came up with.
I ditched the diagonal supports on the back. I made another frame for the front. The top rail is a 2x4. This is supported by another 2x4 that I ripped down to 2x2, and then counter sunk screws every 6 inches across. There's also two 3/8" eye-bolts running through both boards. The front and rear frames are attached with a 2x4 running from front to back, held in place with carriage bolts. Every joint has glue, except for the two boards that run from front to back.
I added another 3/8" eye bolt at each corner, so I can strap it down to the truck bed.
Once strapped down, I can grab the top of the rack and shake the whole truck.
It sits just above the roof line, with the rear being somewhere around 1/2" - 3/4" higher than the front.
Here's the first test, carrying eight 12ft boards of crown moulding. They are strapped down using the eye-bolts on the top, with roughly about 3ft overhang in the front and rear. At 60mph it was pretty solid and never shifted.
As for the color, I had some Red Mahogany wood stain that had been sitting in my garage for a while, and decided to make use of it. After it was complete, I gave it 2 coats of Spar Urethane.
To take it out of the truck, I just remove the carriage bolts from the side boards (4 bolts total) and it comes out in 4 pieces. The front and rear section, and the two side boards. It takes me a total of about 4 minutes to unstrap, unbolt, and remove it from the truck. I can store it up against a wall taking up about as much space as some fold up sawhorses.
I haven't tried it yet, but am curious to see how it will handle a canoe on top, especially considering the canoe will be catching a lot wind resistance.
MT Stringer, SPS-1 and Fix'n it like this.
r0ckstarr is offline   Reply With Quote
Old 07-20-2016, 05:49 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,612
Re: 12ft boards in a 6ft truck bed - DIY truck rack
Ayuh,.... Looks Good,.....
I welded one up for the '79 Ford pickup I was drivin', back in the early '90s,....
Used it on the next 3 trucks, modified it many times, extended it when I went to the club cabs,....
Gonna need a major overhaul before it sees the next truck though,...
Showin' it's age,...
The key to it's versatility is the removable cross-bars,...
The Following User Says Thank You to Bondo For This Useful Post:
r0ckstarr (07-22-2016)
Old 07-20-2016, 06:03 PM   #3
Rewards Points: 24
Nice work!
Sent from my XT1585 using Tapatalk
Premium08 is offline   Reply With Quote
The Following User Says Thank You to Premium08 For This Useful Post:
Old 07-20-2016, 07:10 PM   #4
Usually Confused
lenaitch's Avatar
Rewards Points: 1,958
I like it! Is there a base to the front section similar to the rear? Otherwise, how do you keep the front from wanting to pivot on the side braces and possibly banging up your cab? Just the tightness of the carriage bolts and tie-downs?
I have the same problems of carrying long lumber in my mid-size truck plus lack of storage space between uses. This could be a project. Tnx.
lenaitch is offline   Reply With Quote
The Following User Says Thank You to lenaitch For This Useful Post:
Old 07-20-2016, 08:27 PM   #5
Rewards Points: 236
i have an S-10 x-cab. i thought about doing just what you did. but, what i do = open the sliding window, slide the boards into the cab, sometimes up to the dash. strap em down real good. put flags on what hangs over the tailgate. no problems yet. and i have had well over 12' boards.
r0ckstarr likes this.
Fix'n it is offline   Reply With Quote
Old 07-20-2016, 09:42 PM   #6
Rewards Points: 2,368
That rack is useful, and well thought out.
EXCELLENT.
Back in the day 20 + years ago I had an 84 Ranger 4X4 the same color as yours, with the same paint flaws on the hood, seems that Ford Silver is lousy in the sun.
Good use of using what you have to do the job needed.
ED
de-nagorg is online now   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
Old 07-22-2016, 10:09 AM   #7
r0ckstarr's Avatar
It's built to sit right up against the tailgate, and the front of the bed, with no wiggle room in-between. There's no room for it to move forward or backward. The carriage bolts in the side boards really stiffen it up once tightened down. After I pull the straps tight at each corner, it doesn't move at all. I can grab it and shake the whole truck around with it. It's like a solid box. I left the "feet" on the back piece thinking that I would need them to keep it from moving, but after using it and seeing how solid it is, I don't think I will keep them. I may shorten them down to make it easier to store.
I also considered another board similar to the side boards, but running front to back in the center of the tops to keep it from wanting to fold in. I've decided against that, because it won't fold in, and also because once the boards I was hauling were strapped down, they did just what the extra board would have done.
As for banging up the bed of my truck, I don't think it would dent it due to the lack of room for it to move. As far as scratches inside the bed are concerned, well, they wouldn't be the first. But, I was thinking about putting some kind of padding everywhere that it does come in contact with the bed just in case.
EXCELLENT.
ED
Thanks. I'd like to have one of the older 4x4 Rangers. I think they're still nice looking trucks.
In the 2nd to the last pic, you can sort of see my '04 Ranger. It's a lighter shade of silver, but is already showing signs of the clear starting to flake off on the top of the bed. I used to wax the '96 once every 3-4 months, but once the paint started coming off, I just gave up on it. If it makes it to 400k problem free miles, I'll have it repainted.
The Following User Says Thank You to r0ckstarr For This Useful Post:
lenaitch (07-22-2016)
Old 07-22-2016, 11:01 AM   #8
Rewards Points: 201
No problem with what you built, but it would have been a lot simpler to purchase a truck bed extender from Harbor Freight for $69.99.
Arky
Arky217 is offline   Reply With Quote
The Following User Says Thank You to Arky217 For This Useful Post:
Old 07-22-2016, 12:25 PM   #9
Knows Enough to be Danger
Rewards Points: 779
Arky
That's what I did, but the OP's rack will allow him to get wider cargo
NickTheGreat is offline   Reply With Quote
The Following User Says Thank You to NickTheGreat For This Useful Post:
Old 07-22-2016, 02:37 PM   #10
r0ckstarr's Avatar
Arky
If I got that, then I would have to get the receiver as well. Neither of my trucks has one. The description says that it extends the truck bed by 3ft.
So, 9ft of bed, and 3ft of overhang isn't bad on a 12ft board, but, what about something longer, like a 15ft canoe? There would be 6ft of boat hanging out of the back.
With my setup, I can strap the canoe to the wooden rack, use the foam blocks that go between the canoe and car roof, and strap the front of the canoe down to the front of the truck with minimal overhang on both ends.
This:
or this?
Old 07-22-2016, 09:02 PM   #11
Rewards Points: 386
I thought of building something similar to haul a 32' two-section ladder around. Similar problem. I also thought of maybe building a kind of a side-rack that would carry things on the passenger side. Never got around to it yet.
ChuckF. is offline   Reply With Quote
Vinyl Siding Install: Remove Current Lap Boards? Smahoney6 Building & Construction 22 05-30-2013 04:23 PM
Replacing deck boards lisfisher Building & Construction 6 04-29-2013 11:02 AM
Best way to move fridge on masonite boards so I don't scratch new floor? Studly Flooring 2 11-26-2012 08:57 PM
Proper way to install rake trim boards on long roof peak? jubee Building & Construction 12 09-15-2012 03:01 PM
hardwood flooring boards matjone Flooring 4 02-01-2008 05:35 PM
