12 X 5 Ft Granite Steps ? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-17-2012, 08:34 PM   #1
12 x 5 ft granite steps ?
do I need to have a french door if my entry steps are 12 ft wide ?
gdscannell is offline   Reply With Quote
Old 02-17-2012, 08:52 PM   #2
Rewards Points: 13,458
There's hundreds of differant ways you could go with steps that wide.
Sounds more like a porch then a step.
How about a picture?
Old 02-18-2012, 12:29 AM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Most codes call for a railing down the center (anything over 6ft) FYI.
Iron pipe for example.
And you don't need a French door.
Any door at least 3' will do.
Put a 6 or 8' slider in.
titanoman is offline   Reply With Quote
Old 02-18-2012, 08:39 AM   #4
A french dooor would look better, be more air tight, less parts to fail.
Old 02-18-2012, 09:02 AM   #5
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
A pic or at least a better description of what you want to do would be helpful.
FWIW, granite is a bad choice for exterior stairs. Extremely slippery when wet.
Old 02-18-2012, 08:07 PM   #6
Registered User
Termite's Avatar
The International Residential Code makes no such requirement.
Gdscannell, the width of the door does not dictate the width of the steps. The width of the landing at the top of the steps must be as wide as the steps. But you could put a 3-0 door at the top of a 12' wide stair, provided your landing is 12' wide. The exception to this would/could be interior flights where a landing is not required provided the door does not swing over the stair...Many building inspectors (and people using the stair) would take exception to that.
Old 02-18-2012, 08:10 PM   #7
Registered User
Termite's Avatar
Polished granite would be no good, that's for sure! But granite is commonly used outdoors for stairs....They hit it with fire to cause the surface to chip away, leaving a fairly rough texture.
The Following User Says Thank You to Termite For This Useful Post:
Blondesense (02-19-2012)
Old 02-19-2012, 09:43 AM   #8
Civil Engineer
Rewards Points: 4,700
Many folks in my area have granite steps, they pay a premium to get them. As Termite indicated, they are not polished granite, the only place I have seen polished granite used is for memorial stones, and once in a while for tile in dry areas. The granite steps are often very rough cut, and are not slippery at all. I have a couple of granite pieces that we incorporated into our brick walkway, they look pretty nice.
Daniel Holzman is online now   Reply With Quote
Is this a lousy granite installation? timbo59 Kitchen & Bath Remodeling 70 05-16-2013 10:08 PM
Finding a good granite fabricator for kitchen countertop tseverson Kitchen & Bath Remodeling 5 04-20-2012 02:50 AM
Do you have a Wood/Pellet Stove Insert with a Raised GRANITE Hearth? gmoom Remodeling 1 01-24-2011 04:54 PM
Stonemark & Silestone Countertops......??? DepotDweller Remodeling 9 06-25-2009 11:44 AM
