10A Electric Shock - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-02-2010, 02:30 PM   #1
10A electric shock
I got hit today with 10Ampers and 220V electricity. While i was holding a metal desk with one hand I touched the power line of 10A 220V with other. The force went in from my hand through my heart and chest and went out from other hand.
I read that even 0.2A is lethal, so why didnt it strike me down?
I felt a bit bad and nauseous. I then called an ambulance and they took me to hospital where they kept me for 3-4 hours, and let home after checking all the data, which came out clear.
For now its been about 8 hours and i still feel a bit bad and little pain in chest, but nothing else. Should i be worried at all anymore?
whoyou1 is offline   Reply With Quote
Old 06-02-2010, 03:04 PM   #2
I'm thinking back to university physics here, and it's been a while. But:
Voltage = Current (amps) * Resistance
So if that circuit is 220V, then the resistance in the wire to generate 10 amps is (220 / 10) = 22 Ohms
The average person is 100,000 ohms dry (if I remember right) and 1,000 ohms wet.
So dry you would have gotten (220 / 100,000) = 0.0022 Amps (which is similar to what you described)
If wet you would have gotten 2.2 amps, and you'd be very dead.
Touching the desk just gives a path for the electricity once it leaves you, it doesn't change your resistance.
That being said, I could be completely wrong (someone let me know please), this is just what I remember.
Troglodyte is offline   Reply With Quote
Old 06-02-2010, 03:19 PM   #3
It still doesn't clarify why i got such a heavy hit, i was totally shocked.
Old 06-02-2010, 03:30 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
the easiest answer is:
because the physics in place allowed it to be.
Without knowing absolutely everything about the situation, it is impossible to determine why you got shocked or how much current actually flowed.
anyway, there is documentation showing that a person that is shocked can die hours after the shock due to cardiac or respiratory arrest. If you are feeling bad, I would suggest not being alone until at least tomorrow.
You should drink to replenish the electrolytes in your system. Gatorade would be good, or at least water.
chances are you were only hit with 120 volts. In a US residential situation, each line of a 220 volt circuit carries 120 volts. You would have had to make a line to line connection to be subjected to 220 (actually 240) volts.
also, can be doesn't mean it always will be. Think about people hit with lightning: some survive, some don't.
Old 06-02-2010, 03:37 PM   #5
You got hit with 0.002 amps of electricity which is 1/50th of what would kill you. That sounds like a pretty severe shock to me.
Also 0.1 amps is lethal, less than that is still often lethal, as in Tasers which have killed people with as little as 0.01 amps (which is only 5X more than you likely got).
What I can say is there is no way you got 10 amps, you are not as conductive as copper wire. When you put your finger over a 9V battery you don't really feel anything. Put your tongue over it and you feel a lot more, due to the difference in resistance between your finger and your very wet tongue.
Old 06-02-2010, 03:38 PM   #6
Not living @ US, Europe actually. I was @ the hospital for 3-4 hours and they found nothing. What about sleeping, i suppose noone can spectate me then :P
Old 06-02-2010, 04:12 PM   #7
nap
You talking to me?
nap's Avatar
Ok, so you probably got hit with whatever your single line voltage is (I can never remember the foreign systems)
. It's what, already at least 1 am where you are? How long ago did this happen?
Old 06-02-2010, 04:20 PM   #8
this happened about 12 hours ago, and it is 0.20am
I'm feeling weird @ my left chest, about where the heart is, but it isnt painful.
And a bit shaky.
Old 06-02-2010, 04:24 PM   #9
Learning by Doing
Leah Frances's Avatar
whoyou - hopefully this misadventure in electrical happened in a country with some good nationalized health care. Drag yourself back to the hospital. Might as well spend the night there to be on the safe side.
Good luck
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
The Following 2 Users Say Thank You to Leah Frances For This Useful Post:
gma2rjc (06-02-2010), kwikfishron (06-02-2010)
Old 06-02-2010, 04:33 PM   #10
Rewards Points: 590
operagost is offline   Reply With Quote
Old 06-02-2010, 04:35 PM   #11
Health care is great here, but im not going back there, not feeling THAT bad..
Old 06-02-2010, 04:39 PM   #12
I got hit today with . . .220V electricity.
If most peoples' skin/body resistance most of the time is between 300 and 3000 ohms you got hit with 0.7A to 0.07A.
http://www.google.com/search?client=...UTF-8&oe=UTF-8
An elec. chair is 4A to 8A at 2400 vac. so the executionee is presenting 300 to 600 ohms.
Old 06-02-2010, 04:41 PM   #13
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by Troglodyte View Post
You got hit with 0.002 amps......
I think there is a decimal point problem here, but you could have had momentarily something in the 0.1 to 0.2 amp range flowing through your body. Trog is right,the current flow though your body was not near 10 amps.
http://www.physics.ohio-state.edu/~p616/safety/fatal_current.html
Disclaimer
& Stay Safe
.....Bob Lavery
Old 06-02-2010, 04:47 PM   #14
Well, i was hit fast and then i let go instantly, first i didnt feel so bad, after that i felt a bit sick. Called to 911 and they sent an escort, even tho my symptoms were not that great.
Old 06-02-2010, 04:48 PM   #15
http://ecmweb.com/ops_maintenance/el...auma-20090601/
Supposedly the able-to-let-go current is <18 mA.
(220v^2)/300 ohms for one second is 160 joules, about equal in energy to two 0.45 slugs. More than 1 joule can be fatal and those defibrillator machines can put out 200 joules.
You would have been 1 of 1300 people in the US [out of 300M] who get electrocuted each year. The odds are with you.
String trimmers - gas, corded electric, or battery electric - which one?? whataboutj Landscaping & Lawn Care 43 05-01-2010 09:25 AM
90 amp electric car charger! The future... Billy_Bob Electrical 16 02-16-2010 02:01 PM
Electric shock off bath tap? claire-n-tel Electrical 5 07-25-2009 12:48 PM
Is my panel sufficient to add Electric water heater andy Electrical 16 04-21-2009 08:34 AM
Connecting electric motor to swtich and marine battery Lawnplugger Electrical 5 09-13-2008 01:11 PM
