-   -   100'x40' house (http://www.diychatroom.com/f2/100x40-house-107810/)
Hendo 06-16-2011 06:28 AM
100'x40' house
What should the oc spacing be for the trusses. I was thinking 24". Also what size sheeting on the roof 1/2" or 5/8". All opinions are appreciated.
Dustin
Just Bill 06-16-2011 06:37 AM
Not enough info, depends on a number of things. I doubt you would have a 40' unsupported truss. But usually 24".
Hendo 06-16-2011 07:33 AM
It is a 60x40 house with a attached 40x40 garage. And yes they will be supported with 2x6s. I was just wondering what spacing should use because it's a long building.
rossfingal 06-16-2011 11:14 AM
Whether you're going to use 1/2 or 5/8 sheathing - have them use "clips",
between the trusses.
If you can - plywood sheathing.
rossfingal
Talbot3 06-16-2011 01:42 PM
Space 24" on center and use 5/8" apa rated sheathing. Max span depends on pitch, member size, and loading. My alpine truss span table shows a 2x4 common truss with a 3/12 pitch can span 40' supporting a total load of 40 psf.
jklingel 06-16-2011 04:39 PM
Above advice on the span it right. See your truss guy/gal. Trusses are usually 24" OC, but they don't have to be. 2x6 studs are likely OK, but it depends on your snow/wind loads and ceiling height. My trusses will be 2x4 and 2x6, 24" OC, span 42', with a 5:12 slope. I would never use less than 5/8" ply on the roof, and clips, as mentioned. I am not a fan of OSB anywhere; it you get a roof leak, it may well turn to "oatmeal" (quoted from Martin Holaday on greenbuildingadvisor.com). I would have said "sh**" but that is too rude for some forums. Make sure your foundation is skookum, too; that span could generate a significant load.
