10 X 8.3 Ft Base :((((( - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-23-2014, 07:30 PM   #1
Rewards Points: 22
10 x 8.3 ft base :(((((
I'm obviously an amateur , I have an arrow metal shed in a box I'm about to built. It's a 10 x 8
I made a base out of pressure treated 2 x 4. I wasn't thinking when putting it together and basically I now have a 10 x 8.3 for base.
I use two 2 x 4 x 10 for the front and back. Then I used eight 2 x 4 x 8 at 16 inch centres all along the middle. I then bought 4 x 8 ft sheets of OSB for the top floor of the base. I now have a few inches gap when I put the sheets across as it's not 8 foot width its 8.3ft
I really don't want to take it all apart
Any idea as to the best way to nail the sheets down? Cut it up?
alangolding25 is offline   Reply With Quote
Old 10-23-2014, 07:42 PM   #2
Rewards Points: 270
I think you"ll be a lot happier if you do it right. Just lift the end that's too long,set it up on blocks or something,and cut the over length. Then you"ll have a 8' board on the ground with stubs attached to it.Knock those off and renail your 8' back onto the end of your shortened frame. Shouldn't take more than 20 minutes.[being a dyi'er I have experience with the same type of mistakes!]
Worst thing I see with your plan is the osb for floor.How thick? It goona be spongy,and I don't think it will last very long.
flhtcu is offline   Reply With Quote
Old 10-23-2014, 07:48 PM   #3
kwikfishron's Avatar
Rewards Points: 92
You don't need to take it all apart. Just remove the rim on one side and cut the joist back 3".
You'll be glad you did. You definitely do not want the floor to exceed the footprint of the shed.
Ya made a mistake, fix it and lessened learned.
kwikfishron is online now   Reply With Quote
Old 10-23-2014, 07:48 PM   #4
Rewards Points: 270
Oh,Assemble your metal bottom frame right now-and measure it..if I remember correctly,that's the first step anyway-. The base of the shed might be just a bit different than 8x10.
I had the 10x12 Arrow,and I liked it,but it got crunched by a tree.
Old 10-23-2014, 07:58 PM   #5
Rewards Points: 22
Thanks for the replies. Taking the off and cutting them down 4 inches sounds like a good plan.
Only thing is I used joist hangers for each joist and they are nailed in will take a while to get them off
The Osb does seem a bit spongy alright. It's 5/8's thick.
I think you are all right
Tomorrow I will bring back the Osb and get plywood
Take off the back and cut each joist down 4 inches I'll use the skill saw to make sure it's straight
Set shower base in mud svaic00 Plumbing 2 06-06-2013 08:27 PM
Fix For ELM Shower Base Drain Leaks MarkSilber Plumbing 0 02-14-2012 10:02 AM
Installing a Sterling shower receptor in a mortar base repoocaj Plumbing 2 11-19-2011 08:52 AM
Sink base vs regular base cabinets... J187 Kitchen & Bath Remodeling 3 12-03-2010 08:40 AM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 10:10 AM
