1/4 Inch (6mm) Glass Stength? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-29-2010, 03:32 AM   #1
1/4 inch (6mm) Glass Stength?
First of all, Hi from Australia!
I'm trying to put a glass shelf together to go on the top of a cabinet and was wondering what sort of length I can span (horizontally) with a 1/4 inch thick glass sheet? My shelf is roughly 34 inches long by 11.5 inches wide. I'm just trying to work out what thickness of glass I will need to be strong enough to cover this distance. It will not be weight-bearing.
Anyone with advice would be most appreciated.
Regards, Kev
KevOZ is offline   Reply With Quote
Old 06-29-2010, 08:42 AM   #2
DIY staff
Rewards Points: 7,174
That shelf should span 36 inches with only end support. Light objects only.
My folks owned a gift shop--long ago,many of the display racks were 36".
I did collapse one when I over loaded it with jars of jelly,double stacked.--Mike--
Old 06-29-2010, 09:35 AM   #3
Old School
cabinetman's Avatar
For that length it may show some deflection from self weight. If light weight is not centered the deflection may not be that obvious. As a failsafe, 3/8" would be a better choice.
cabinetman is offline   Reply With Quote
Old 06-29-2010, 09:40 AM   #4
the Musigician
DangerMouse's Avatar
If you add a piece of 1/4 round trim along the back edge, it'd greatly improve strength.
If you have particle board on the back, use construction adhesive to attach instead of nails/screws.
DM
Glass on greenhouse roof Flavio Building & Construction 16 07-15-2010 07:37 AM
240V 2 pole 1/2 inch GE breakers? Isaac-1 Electrical 12 02-09-2010 11:21 AM
Question about GLASS bsmith6356 General DIY Discussions 2 06-26-2009 11:51 AM
Impact Windows & French Doors Matty16 Carpentry 6 06-22-2009 09:01 PM
Help with replacing some glass shonkster Building & Construction 5 03-12-2009 05:24 PM
