-   -   1/2" Polyisocyanurate as underlayment for laminate (http://www.diychatroom.com/f2/1-2-polyisocyanurate-underlayment-laminate-65776/)
Hawss Drew 03-02-2010 09:49 AM
I was wondering if I could do this. I have a finished lower level in a split level house, and the previous owner just put laminate down on the concrete floor, with only 6 mil sheeting between concrete and laminate flooring.
I'm wondering if I can use 1/2" Polyiso as underlayment? It's rated for 25 PSI, which isn't a lot, but the laminate flooring over top of it i think would help spread the total weight pushing down on the polyiso.
I have a door that goes to the garage down stairs, so I can only go about .75" before I run into the bottom of the door. I'd like to stay well below that, and within height codes.
Is this feasible?
Ron6519 03-02-2010 01:59 PM
I don't think so. I would secure a plywood layer above and cut the door.
Ron
Hawss Drew 03-02-2010 02:13 PM
It's an exterior door with weather stripping, I don't think I can just cut it.
Ron6519 03-02-2010 05:38 PM
You might be able to reset the whole door unit so the floor can be adjusted.
You can forget the whole, " raise the floor thing" and just put down an area rug to add some warmth underneath by isolating the floor from the feet.
You might be able to lay down homosote board over the concrete to isolate the floor. You would need to check with the manufacturer if it will carry the load without inordinate deflection.
Ron
