Zinking Foundation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-17-2013, 01:59 AM   #1
Zinking foundation
I constructed an addition to my existing house 4 years back.
Everything is to the standard and tested and received Council certificate.
Recently i have noticed one of my door sticked to the door frame. Through out the last 12 months I have planed the door several times . Still door is hard to close and open need to plane it again.
I feel the whole foundation has sunk by few MM. No other cracks and bends. there are two door in the same direction, both do the same, Is there any suggestions how to prevent this.
I can go the under house, house is built on top of the piles.
Can I stop this by installing more bracings?
mpj111 is offline   Reply With Quote
Old 03-17-2013, 07:20 AM   #2
Rewards Points: 4,534
bracing won't but foundation supports will might have low weight bearing issues so i'd get a pro - engineer 1st, tho
Old 03-17-2013, 09:18 AM   #3
Rewards Points: 13,270
Post a picture. Hard to suggest a fix to something we can not see.
Exactly where is the door sticking?
Also please go back and add your location to your profile.
Just go to quick links and edit.
Old 03-17-2013, 09:31 AM   #4
AHH, SPANS!!!
Rewards Points: 1,166
if you go under the house directly below where the door is you will see the support for that area and make the determination from what you see under. it could need a column added or may need to fortify a pre existing column because it is sinking into the soil. I've found roots under houses affecting columns and water flowing under houses causing ditching around columns and cracking red clay backfill is one of the worst for house settlement, so there is no telling what you will find...
hand drive is offline   Reply With Quote
Old 03-17-2013, 11:56 AM   #5
GBrackins's Avatar
Rewards Points: 2,108
you can try many things to see if they work, spend time and money on suggestions made
my money would be on hiring a professional engineer to come to your home and evaluate the structure. they can determine what is going on and plan a proper course of action. this way when you go to fix it you'll do it once and save some time and money.
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 03-17-2013, 12:25 PM   #6
kwikfishron's Avatar
Rewards Points: 176
Replace a couple of the top hinge screws with 2 1/2-3" screws and see if that picks the door up before you call out the Engineers.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
jomama45 (03-18-2013)
Foundation wall project and spread footings WillK Building & Construction 0 08-31-2011 01:46 PM
Stone Foundation 'Temporary' Repair... Peter B. Building & Construction 17 12-16-2010 01:27 PM
moist soil under raised foundation during winter bn300 Building & Construction 0 09-17-2010 03:51 AM
Round House Foundation Feasibility Mswick Building & Construction 23 02-27-2010 09:34 AM
Foundation Repair Help rasilun Remodeling 1 10-15-2009 11:26 PM
