Your Thoughts On Framing Plan... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-15-2012, 11:07 PM   #1
Your thoughts on framing plan...
I am planning on building a small cabin, 16'x 36', on a pier and beam foundation with 12"sonotubes, with a slanted shed-style roof.
I want to build with 2x8's for the walls", to accomodate r-35 insulation, 2x10's for the floor joists with double 2x12 beams, and 2x10 rafters. r-40 insulation in the floor and ceiling.
This is my first diy effort to build something, and any advice would be appreciated.
I am considered to be a "handyman" by people that know me.
wwsteel7 is offline   Reply With Quote
Old 01-15-2012, 11:09 PM   #2
Rewards Points: 506
Sounds heavy duty.
jlmran is offline   Reply With Quote
The Following User Says Thank You to jlmran For This Useful Post:
gregzoll (01-16-2012)
Old 01-15-2012, 11:13 PM   #3
yeah, primarily too accomodate the insulation
Old 01-16-2012, 12:51 AM   #4
Rewards Points: 2,212
Some have gone to double 2x4 with 2x8 plates, offset the studs so inside and outside wall only connect at the plates. Helps with thermal transfer
mae-ling is offline   Reply With Quote
Old 01-16-2012, 08:57 AM   #5
Rewards Points: 3,130
Are you going to need a building permit for this? If so, your plans will require approval. One thing does jump out at me: unless your're using some type of insulation I've not heard of, or are spray foaming, your studs, joists, and rafters aren't big enough for the level of insulation you say you want.
Old 01-16-2012, 09:16 AM   #6
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Yeah. You're trying to pack too much insulation in your proposed bay depths.
titanoman is offline   Reply With Quote
Old 01-16-2012, 09:17 AM   #7
Disabled wood vet
titanoman's Avatar
Old 01-16-2012, 10:04 AM   #8
Originally Posted by titanoman View Post
Yes. Also a common practice for soundproofing.
Old 01-16-2012, 01:01 PM   #9
Thats what I'd recommend
mrgins is offline   Reply With Quote
Old 01-16-2012, 02:53 PM   #10
You put the studs 16" oc but the inside ones are spaced 8" off the outside ones. So no stud goes completely from the outside to the inside.
Another method is building 2 2x4 walls spaced 3.5" apart and using 3 layers of r12 insulation.
Old 01-16-2012, 03:30 PM   #11
Old School
Willie T's Avatar
This is the idea. If using two plates, the space between them assures minimal sound transmission.
Usually, the insulation is woven between the studs... side to side, instead of up and down. On the double plate walls, you can do more layers, installing it normally (up and down) on the back wall first, then the inside wall... and even one woven in between if you want.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
mae-ling (01-16-2012)
Old 01-16-2012, 04:23 PM   #12
You could also use R15 which fits into a 3.5" space
Old 01-16-2012, 06:36 PM   #13
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,358
ive never heard of staggered stud walls working for a extra r- rating, its primarily for stc ratings.
using 2x8 will work, but it will not only cost more but will also be much harder to stand the walls from the added weight
regarding the last post , if this place is to be inspected r-15 insulation wont pass an inspection. in most regions the minimum is r-24 which is achieved by framing 2x6 walls and either using r-19 batts and 1" of foam on the exterior or by using r-24 batts
woodworkbykirk is online now   Reply With Quote
Old 01-16-2012, 06:43 PM   #14
Using three layers of 3.5" batts, as a previous poster suggested, would give a nominal combined rating of R45. I'm not saying it's the cheapest or most efficient, but it's not the R15 that you assumed
pocket hole jointery and cabinet screws for framing newbymodeler Carpentry 29 03-07-2013 03:17 PM
retro framing sole plates to subfloor/hardwood amakarevic Carpentry 2 03-20-2011 01:45 PM
Double Framing on old Garage? bofusmosby Building & Construction 6 04-12-2010 09:08 PM
framing material estimate maydoug Building & Construction 38 06-12-2009 01:32 PM
Framing 2x4 cabinet/wall gone_fishing Carpentry 1 01-05-2009 07:14 AM
