YIKES !!! JOIST IS CRACKED IN TWO --how Do I Fix? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-15-2010, 02:06 PM   #1
Dyoung's Avatar
YIKES !!! JOIST IS CRACKED IN TWO --how do I fix?
1959 house.
Got a 2 x 12 joist in my basement that has a huge knot running from top of beam to bottom. Joist was one of 5 that supported heavy concrete bathroom walls, floor, cast iron tub etc.
As a result of age, weight and stupid knot, the joist has nearly cracked through with a mere 3-4 inches of remaining connective wood.
HOW CAN I REPAIR THIS ~SAFELY~? Or should I simply replace it?
The caveat: I am about to put in a new bathroom subfloor on a deadline here. I wont be installing the ceramic floor tiling for a few weeks so I thought I could cut out the old beam and install a new one when most of the bathroom work (except for the ceramic floor tiling) is completed.... There are beams I can still reach with new subflooring now that wont require the broken one at the moment. When I install the new joist I would then screw that part of the floor down then finish off with my ceramic floor tiling. Does this plan makes logical sense?
Dyoung is offline   Reply With Quote
Old 02-15-2010, 02:22 PM   #2
jlhaslip's Avatar
Rewards Points: 2,096
leave the existing one in place and 'sister' another one to it. You will likely need to involve a jacking system, glues, clamps, nails and a few buddies.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 02-15-2010, 02:36 PM   #3
Dyoung's Avatar
Why not simply replace it?
Old 02-15-2010, 02:38 PM   #4
jlhaslip's Avatar
might be nailed to the floor or have stuff connected to it and getting the nails removed to allow for the other one to sit back in the same place is a pain in the a$$, but you can try.
Old 02-15-2010, 03:53 PM   #5
Civil Engineer
Rewards Points: 4,768
The more logical question is why bother removing it? If it is still level, you can sister a new one to it without any jacks. Also there is no need to use glue to connect the sistered joist to the old joist, use the appropriate nails, structural screws or through bolts at the appropriate spacing (check with your local code enforcement officer for proper spacing and size of fasteners).
In most cases horizontal shear controls the size and spacing requirements for fasteners, so you select the fastener pattern to develop the required horizontal shear for the connection. Direct shear almost never controls this type of application. If you don't care to do the math for horizontal shear, you can probably use 16p nails 6 inches on center staggered, or equivalent structural screws, or you can use bolts. The size and spacing of the bolts should be computed based on horizontal shear requirements.
Daniel Holzman is online now   Reply With Quote
Old 02-15-2010, 04:00 PM   #6
why horizontal and not vertical shear Daniel
The older I get the better I was
Old 02-16-2010, 06:31 AM   #7
Follow the posts do not remove it just sister one to it and through bolt it with heavy duty nuts, bolts and washers. Make sure the new sistered joist is crowned and is tight to the bottom of the floor and level before thru bolting.
SULTINI is offline   Reply With Quote
Old 02-16-2010, 07:51 AM   #8
You have to connect SISTER JOISTS alongside the defective joist or run a structural beam perpendicular to the bad joists.
You can also build a BEARING WALL underneath that area for support.
Robbie245 is offline   Reply With Quote
Cracked Floor Joist - what to do? Knucklez Building & Construction 25 08-10-2010 01:21 PM
Space between joist and beam on deck schveiguy Building & Construction 11 09-08-2009 09:15 AM
one rotted deck joist to replace, need advice dougq Building & Construction 10 07-07-2009 02:18 PM
floor joist issue drtbk4ever Building & Construction 4 03-22-2009 10:20 AM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
