Yet Another Framing Question... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-04-2012, 07:27 PM   #1
Weekend Warrior
Yet another framing question...
Back story: I am finishing a basement and decided to keep the insulation they use to wrap up unfinished basements in place. With this I am placing my framing an inch and a half from the foundation wall. Even with this extra room the insulation likes to push back a little when moving the wall plumb. No problem that a quick nailing to the joist can't fix. Now comes my problem....
One of my walls has HVAC duct running along it. Because of this I cannot simply nail the top plate into the floor joist once the wall is in position. So I'm wondering if this is a possible solution. Take some plumbers tape and nail one side into the foundation wall, wrap the tape around the stud until plumb and then screw/nail the tape to the stud.
Pictures included below (I wanted to get options/opinions before committing to the whole wall.) Thank you.
Mesoneer is offline   Reply With Quote
Old 02-04-2012, 07:34 PM   #2
Rewards Points: 13,456
The wall should have been built out far enough to clear the pipe. The pipe should have been insulated before any wall went up. The top plate and wall were built all wrong unless you plan on adding another 2 X 4 where the butt joints on the top plate meet. (should have been done before the wall even went up.)
Mesoneer (02-04-2012)
Old 02-04-2012, 08:12 PM   #3
Weekend Warrior
Unfortunately I need all the space I can get on that wall, so I can't build the wall to clear the heater vent. I will instead be boxing them in. If this idea doesn't seem feesable, how about attaching a a couple 2x4's to the wall and nailing into them? Otherwise my only other option is taking down the duct work and building the wall to the joists then fitting the duct back again (shouldn't be too bad since I only have 2 vents connected to that trunk).
Old 02-04-2012, 08:53 PM   #4
Framing Contractor
Very easy. Make 2x4 blocks about .12"....nail them together as an L....nail that to the foundation and nail the wall stud to that...
Joe Carola
Joe Carola is offline   Reply With Quote
Old 02-04-2012, 10:28 PM   #5
Registered User
Rewards Points: 5,492
The plastic should not be there as it's only for passing inspection for an unfinished basement; http://www.buildingscience.com/docum...lation-systems
I would air seal the rim joists with rigid foam board, caulk/canned foam the perimeters against air leaks, and reinstall the f.g. insulation:http://www.buildingscience.com/docum...l_seal_rev.pdf
Also, fire-block above the duct work with material to stop the wall/ceiling fire path and the wall every 10' lineally; http://publicecodes.citation.com/ico...002_par031.htm
Page #2: How to fireblock framing
Gary
Shed Roof Fascia and Framing Question crhage Building & Construction 3 06-22-2011 06:54 AM
Above grade framing and a few framing question jreed Building & Construction 6 01-16-2010 10:56 AM
Framing Question flati Building & Construction 10 01-12-2010 10:24 AM
Balloon Framing Question zetti1102 Building & Construction 2 09-30-2009 09:50 PM
stupid framing question amakarevic Building & Construction 12 02-23-2008 03:29 PM
