Old 10-18-2012, 07:58 PM   #1
Yes, another another ledger board thread...
Sorry to highjack the thread but iam getting ready to build a deck.And was wondering the best way to attach and flash ledger board that is on concrete basement wall.Is it best to use wedge bolts or to go all the way thru the wall?And iam not sure how to flash since there is no siding that low.btw deck is 14'x14'.
scottktmrider is offline   Reply With Quote
Old 10-18-2012, 08:37 PM   #2
Wedge bolts are OK, Through are better but usually not needed.
This is one possible case where spacers between the deck and concrete can be used. spacers can be a washer a just slightly larger nut then another washer. Or you can get ones in some areas made of plastic.
Drill holes through ledger and put treatment in them.
Caulk the holes in the concrete the bolts go through.
mae-ling is offline   Reply With Quote
Ledger Board Mounting to Rim Joist markjohnson Building & Construction 10 09-21-2012 12:08 AM
Different way to mount ledger board? WicRules Building & Construction 13 09-09-2012 12:16 PM
garage loft; ledger to ledger joists? nsixbdg Building & Construction 10 12-26-2011 07:29 PM
ledger board tjlacy Tiling, ceramics, marble 6 03-05-2011 12:50 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
