XPS Or Polyisocyanurate For Basement - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-05-2010, 11:50 AM   #16
Registered User
Rewards Points: 526
http://www.lowes.com/pd_135512-56291...CatalogDisplay
http://www.lowes.com/pd_96179-1410-T...20tape$y=0$x=0
Be safe, Gary
Old 08-05-2010, 12:07 PM   #17
Rewards Points: 640
ah thank you, was looking for the wrong stuff then!
BlueBSH is offline   Reply With Quote
Old 08-05-2010, 12:56 PM   #18
Rewards Points: 93
The tape that I use is indeed made by Tyvek. My local Home Depot has them. I have seen a similar product made by Lowes, but haven't actually tried it.
http://www.lowes.com/pd_103366-210-T...ductId=3006052
I also have ducts running in some of the rim joists. I used fiberglass in those. The rest I used XPS.
The XPS that I am using have tongue/groove. I don't find them particularly useful as they don't always line up. Probably it is because my basement has concrete blocks and they are not perfectly flat. I am using tape on the joints anyway.
Check if your town requires fire blocking. If so, I would suggest doing that first after you seal all the rim joists.
leungw is offline   Reply With Quote
Old 08-05-2010, 08:07 PM   #19
Rewards Points: 410
Caulk the groove full of PL , you won't need tape.
I glue the heck out of the foam , air gets around it you've gained nothing IMO.
High Gear is offline   Reply With Quote
1/2" Polyisocyanurate as underlayment for laminate Hawss Drew General DIY Discussions 3 03-02-2010 05:38 PM
foil-faced polyisocyanurate in walls rmcfall Building & Construction 0 12-14-2009 05:05 PM
