XPS Or Polyisocyanurate For Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-31-2010, 12:19 PM   #1
Rewards Points: 640
XPS or Polyisocyanurate for basement
I'm about a few weeks away from starting my insulation project in the basement... was just about to order the rigid foam and noticed that polyisocyanurate foam is strangely cheaper... I was always under the impression it was more expensive..... anyways which of these would you buy? Keep in mind I am going to put a 2x4 wall infront of this and add R-13 to that in addition to this foam board....
Dow STYROFOAM 3/4" x 4' x 8' R4 Insulated Sheathing $17.72 per sheet
http://www.lowes.com/pd_14545-46086-..._?rpp=15$No=15
or
Dow 3/4" x 8' x 4' R-5 Polyisocyanurate Rigid $12.98 per sheet
http://www.lowes.com/pd_42821-236-26..._?rpp=15$No=15
BlueBSH is offline   Reply With Quote
Old 07-31-2010, 03:36 PM   #2
Registered User
Rewards Points: 526
http://www.buildingscience.com/docum...gs?full_view=1
Be safe, Gary
Old 07-31-2010, 03:50 PM   #3
Rewards Points: 640
Not really sure that answers my question on which one to use... I already know how to insulate for my situation, just not sure if it matters which one I use or not
Old 07-31-2010, 04:01 PM   #4
Rewards Points: 392
For a basement use the XPS.
rustyjames is offline   Reply With Quote
Old 07-31-2010, 04:12 PM   #5
Registered User
Rewards Points: 526
Sorry. The article brings out to use non-faced foam board. Poli is faced, three layers of : http://docs.google.com/viewer?a=v&q=...dtkIjjvMMJW5yA
You want the water vapor to pass through the board and dry on the room side. Only latex paint, no v.b., no air space, sill sealer under p.t. plate for thermal/capillary break.
More recent studies suggest minimum 2" foam board for thermal protection against condensing.
Be safe, Gary
Old 08-01-2010, 01:29 PM   #6
Rewards Points: 410
XPS tongue & groove
Owens corning 1" XPS 150 T&G is around $10.00 +/- $1 around here.
2" is $20.00 +/- ( Menards )
High Gear is offline   Reply With Quote
Old 08-01-2010, 04:01 PM   #7
Rewards Points: 640
ok I guess one last question... since I am framing a 2x4 wall infront of this and filling it with R-13 fiber glass insulation, should the be faced or not? some stuff I read says yes, some says no the XPS is the vapor barrier (which isn't it semi permiable? doesnt some vapor still get through?)
Old 08-01-2010, 06:20 PM   #8
Rewards Points: 410
http://www.buildingscience.com/docum...lation-systems
Particularly page 9 /10 / & 14 but read it all if you like.
Probably won't find unfaced R-13 , just take the paper off .
Old 08-01-2010, 08:22 PM   #9
Rewards Points: 640
amazingly my local lowes has R-13 batts unfaced available
Old 08-01-2010, 11:08 PM   #10
Rewards Points: 410
Good deal its always nice the less glass dust you stir up.
I have 1" foam with r-13 glass , I will be calling the
plasterer this week.
Old 08-02-2010, 06:40 AM   #11
Rewards Points: 640
when the foam board says "sheething" does that imply it has a facing? I know that means it can be used like plywood sheething is on the outside of the house when it is SIS but you wouldnt use that in a basement would you?
Old 08-04-2010, 10:08 PM   #12
Rewards Points: 97
BlueBSH, I am doing about the same thing as what you are describing. I am using Owens Corning 2" XPS. My local Home Depot has them. About $15 for 2ft x 8ft.
leungw is offline   Reply With Quote
Old 08-04-2010, 11:12 PM   #13
Registered User
Rewards Points: 526
Looking good! Remember required egress from a basement: http://illowaicc.org/uploadedFiles/I...20Openings.pdf
Foam board the rim joist: http://www.rd.com/57548/article57548.html
Sill sealer under the p.t. plate, a capillary and thermal break: http://www.greenbuildingadvisor.com/...-building-code
Be safe, Gary
Old 08-05-2010, 07:56 AM   #14
Rewards Points: 640
Be safe, Gary
I just finished 90% of my rim joist job... hit some snags with it though, some joist cavities had hvac riser ducts going into them for the 2nd floor and they where right against the wood it seemed like... so made it almost impossible to do.... for those ones I just spray foamed around the joints to seal it up then fiberglassed it with R-30 that was about 7 joist bays out of the ~110 joists I had to fill.. currentlu struggling with one 30 ft wall that is one long cavity (its running parallel with the joists) on one end the space is about 3 inches open (due to the basement wall beign framed in 2x4's and drywalled already I lost about 5 inches of space to get into it) so I had to find a way to get it up into there which wasnt hard but foaming around the gaps has been an interesting challange... made myself a longer flexable tube wand to stick up in worked great so far... but the problem is the other end... the gap is only about 1" so I can get the foam in but then I cant see a thing and the gas line comes in there and there is a water faucet... so im stumped on that end on what to do.... once I get that done im done with rim joists..... yay!
now my problem...... XPS in my area doesnt seem to come in toung and groove at lowes..... just "square edge" and lowes is really the only easy to get to lumber store around here anymore...... use to have an 84 lumber but that went away... any problems with using square edge and bonding the pieces together with glue then taping them or what would you do in this case?
Old 08-05-2010, 08:00 AM   #15
Rewards Points: 640
what is the tape called you use on the joints? we always called it tyvek type (yea i know thats a brand... but we always just called it that)... is it just normal housewrap tape? I'm having a heck of a time finding it at lowes....... i can find houe wrap just no tape....
1/2" Polyisocyanurate as underlayment for laminate Hawss Drew General DIY Discussions 3 03-02-2010 05:38 PM
foil-faced polyisocyanurate in walls rmcfall Building & Construction 0 12-14-2009 05:05 PM
