XPS Glued Pattern For Concrete Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-16-2010, 03:02 PM   #1
Rewards Points: 640
XPS glued pattern for concrete walls
Is there a "Best" glue pattern to attach XPS to concrete walls? Or is a few vertical lines of it with the top and bottom also glued horozontally alright? Can't find much information on this online...
BlueBSH is offline   Reply With Quote
Old 08-16-2010, 04:25 PM   #2
Rewards Points: 5,336
You only need it to stay in place. Small globs every 12" or so should be enough. Get the correct adhesive. The wrong ones will just dissolve the foam.
Ron
Old 08-16-2010, 04:27 PM   #3
Rewards Points: 640
Ron
Already got a type that says Foam board to concrete as an acceptable application
Old 08-17-2010, 09:20 AM   #4
Liquid Nail Heavy Duty works and won't disolve the foam. Any PL product (other than the foam board stuff) will melt the foam.
behrend is offline   Reply With Quote
Old 08-17-2010, 09:30 AM   #5
Rewards Points: 640
The PL adheasive I got is tan and it says "any foamboard product" on the list of applications
Smoke Damage:Must Walls be torn out or will Clean / Repaint Work? Solo1 Remodeling 1 10-16-2009 02:20 PM
Insulating walls for heated garage Huskie Building & Construction 5 09-19-2009 01:54 PM
Installing Plumbing in 2Ē Wide Walls? Robert1_1 Plumbing 5 09-16-2009 09:43 AM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 09:17 AM
Re-Painting textured walls: the Frustration New2DIY Painting 20 07-06-2008 04:10 PM
