Wrought Iron Railing Installation?
I had a bunch of old wrought iron railing and I make a couple to fit on my cement steps. The only problem now is I'm not 100% sure how to install them.
How big do I drill the holes? How much if any bigger should the hole be then the part of the railing that goes down into it? From what I've seen thier should be 1/4in or so wiggle room.
What do I fill it with? I know lead is the best way to do it but the equipment is more then I want to invest in for somthing I'll use once. Where would I get my hands on lead for that anyway? Is this a special mix for this or should I use morter, regular sand mix, etc?
