Wrought Iron Railing Dimensions - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-15-2010, 08:58 PM   #1
Rewards Points: 290
Wrought iron railing dimensions
I am rebuilding a exterior 4x12 2nd floor balcony on a 70+ year old stone house. I have replaced the beams and decking and now I am looking at the railing. Rather than just rebuild the wood railing, I was thinking of creating a wrought iron rail (I think its all steel these days), that would match some existing iron grille work. I have a gas welder, and I have found a local metal supply that has all the materials I need.
I was planning on a 36" rail height and 6" picket spacing. Are there codes that say what the minimum rail height and max picket spacing have to be?
tns1 is offline   Reply With Quote
Old 07-16-2010, 11:03 AM   #2
Rewards Points: 290
The only mention I see in the building codes for railing (hand rail) is for stairs and ramps. Code calls for a 34" to 38" hand rail height. No mention of picket spacing. The existing window grills use 5 3/8" spacing. The 6" spacing I plan on is a close visual match and a good fit for the material length.
On the other hand, for safety, I would expect some max spacing so small children don't fall through. On a deck building website I see 4.5" max spacing called out, but not sure if that is arbitrary.
Old 07-16-2010, 12:13 PM   #3
Spacing must be so that a 4" sphere can not pass between the railing/picket
Old 07-16-2010, 05:36 PM   #4
Registered User
Rewards Points: 5,258
Check with your local Inspector. CA- page #11: http://docs.google.com/viewer?a=v&q=...h1W5lElSFXE4_w
Be safe, Gary
Gary in WA is online now   Reply With Quote
Old 07-16-2010, 10:16 PM   #5
Rewards Points: 290
Which says 42" min rail height and 4" max picket opening. That would work out to 36" pickets on 4.5" centers with 1" top and bottom rail and a 4" bottom gap. This is 30% more metal than I want. It won't match as well to what is there already. A 20' stock length gives 7 @ 34".
Are kid's heads really as small as 4 inches? I thought the problem was kids were fatter than ever. Maybe I should just electrify the rail and keep everyone away
Old 07-17-2010, 12:09 PM   #6
Rewards Points: 5,336
Just eliminate the railing altogether. What's the worst that can happen?
Look at all the money you'll save then.
Ron
Oak hand rail on existing iron stair railing dougworm Carpentry 8 05-03-2011 06:54 PM
Oak hand rail on existing iron stair railing SHREDTHESYSTEM Carpentry 9 03-22-2010 06:30 PM
Replace Wrought Iron interior railing esam75 General DIY Discussions 7 03-20-2009 01:20 AM
Replace wrought iron railing mailman Building & Construction 6 07-06-2008 03:29 PM
wobbly wrought iron railing sleeples65 Building & Construction 5 05-20-2008 07:31 PM
