WRB Before Or After Window Install? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-11-2010, 07:57 AM   #1
Rewards Points: 111
WRB before or after window install?
In Jersey I have been seeing people installing new construction windows before wrapping the house with WRB. Any thoughts on this practice? They say back caulking directly to plywood would eliminate the chance of water finding its way behind the window since their is nothing (no wrap) between the two.
Thoughts?
luvdairish is offline   Reply With Quote
Old 06-11-2010, 12:00 PM   #2
Rewards Points: 1,910
I think they're wrong. The lapping will be wrong at the bottom of the window and water will get under the wrb there.
Old 06-11-2010, 12:52 PM   #3
kwikfishron's Avatar
Rewards Points: 86
Thoughts?
And their right.
Itís good for them because if any water gets behind the wrap it wonít leak in the window.
The bad thing is by the time you know you have a problem, the walls half rotted away and their long gone.
kwikfishron is offline   Reply With Quote
Old 06-11-2010, 01:16 PM   #4
Rewards Points: 111
The reason I'm asking is because I'm working a DIY project on my house and am trying to figure the best approach to water protection. Since the previous installers didn't seam to care much about that, I'm repairing all the damage from the old installation
Old 06-11-2010, 02:19 PM   #5
Rewards Points: 5,336
There should be an integrated house wrap and adhesvie membrane flashing tape around the windows. Just caulking the windows fins won't keep water from intrudung behind the siding.
Ron
Old 06-11-2010, 05:14 PM   #6
Rewards Points: 111
Ron
That is understood. But the question is, do you install the window (flashed, caulked and all) before or after the house wrap? My friends argument was, to caulk and flash, then install house wrap. It made sense, but then again I'm not a drop of water
Old 06-11-2010, 05:54 PM   #7
You could do something radical like follow the window manufacturers instructions and the wrb manufacturers instructions. They will be remarkably similar.
Old 06-11-2010, 06:18 PM   #8
the right way is to wrap first but with a 'flap' above the upper flange. The wrap then flaps down over the window.
Pictures explain it better. Scroll to a pic I took of my window install, post 39.
new hardi siding and windows - what have I started? aargh!
derf36 is offline   Reply With Quote
Old 06-11-2010, 06:36 PM   #9
Rewards Points: 111
Quite a few products used in that install. Tyvek, Typar, Grace...nice work!! So many variations on installs and so many products to choose from.
Old 08-03-2010, 11:05 AM   #10
Rewards Points: 212
I realize this project has been completed, but I found some info -- pretty much what was done here (derf36) -- that thought I'd post.
Here is link to housewrap, windows, caulking and typar flex flashing
http://www.finehomebuilding.com/how-...correctly.aspx
I am renovating/rebuilding a porch and am confronted with same question -- What is the proper way to do house wrap and install and seal windows?
I have 2x4 construction and have ordered vinyl windows with brick mold/JTrim and nailing flanges.
My intent is to follow this guide. Any thoughts/comments advice is most welcome.
Thanks.
orange
orange is offline   Reply With Quote
Old 08-03-2010, 04:57 PM   #11
Definitely follow the article as a guide. It has good advice.
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 08:42 PM
Window Installation Questions cumak Building & Construction 0 05-05-2010 01:22 PM
Replace a window with Bay Window? Eusibius2 General DIY Discussions 4 10-09-2009 12:10 PM
Window Install Question Tom5151 Building & Construction 1 09-29-2009 10:34 AM
window install help georgerodr Building & Construction 6 09-08-2007 10:27 AM
