Wrapping A Window - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-09-2009, 11:27 PM   #1
Wrapping a Window
I would like to see how to do this? (Wrapping a Window) I know i will need a Brake, but instruction would be real nice?
splinter2 is offline   Reply With Quote
Old 12-10-2009, 08:49 AM   #2
the Musigician
DangerMouse's Avatar
We moved your post over here. You'll get much faster responses here.
DM
Old 12-10-2009, 09:04 AM   #3
Remodeling Contractor
try searching Youtube videos. Are you referring to wrapping the window trim with aluminum? That would be the only case you must use a brake. Basics in any case is to do the bottom first, then the sides and then the top. Remember that everything on the top must be on what ever is below it. No top edges are open.
Old 12-10-2009, 02:38 PM   #4
Wraping a Window
Thanks Guys, for the Info. I searched Youtube with some videos, i got the basic will try and do some more searching from other places? I guess iam going to look at purchasing a used Brake do you have any ideas on a brand name, Also iam getting ready to run my overhang as well, just need to figure out how to build the returns or boxes so call, guess i'll do a search for how to build them as well..... I love working out in Cold weather? Not really......... its about 15 degrees here today and the wind is blowing about 20 mph, Have a Great day.
Old 12-10-2009, 05:06 PM   #5
the Musigician
look on craigslist in your area for a brake, i see them all the time.
DM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 10:47 AM
