Wrapping Post With Stone - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-19-2011, 09:15 PM   #1
Rewards Points: 790
Wrapping Post with Stone
I have an old seventies looking iron front-porch railing that I'd like to improve the look of. My idea was to cover the iron newel posts with wood 4x4s by routing a groove into the post and sliding the iron post into the wood.
After that I planned on adding slate, stone, or some sort of veneer to the wood post. The iron railing is in really good condition and I'd hate to tear it completely out. I think the iron and stone would look nice. Any ideas on this or previous experience?
cibula11 is offline   Reply With Quote
Old 02-19-2011, 09:41 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Got photo?
XXX
Old 02-20-2011, 12:13 PM   #3
Rewards Points: 790
Originally Posted by Bud Cline View Post
Got photo?
Sorry no pic. The iron railing is black and the current newel posts are only about 1x1. Thinking of either routing out a 4x4 or building a "box" with 1x4 and then wrapping that with the stone.
Old 02-20-2011, 05:07 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I'm not following the need for the wood. It will rot in a short time. Why not just stack the stone? I must be missing something.
XXX
Old 02-20-2011, 09:04 PM   #5
Rewards Points: 790
The iron railing is currently in place and the entire railing is iron. I was thinking of covering the posts (which are iron) with wood, so that i could build them out large enough to wrap with stone.
Old 02-20-2011, 09:18 PM   #6
remodeling pro
As said, there is no need for the wood, just build the stone columns whatever size you want; you can fill the inside with mortar as you work you way up, if you like. The wood will only warp and twist, and destroy the stone work.
troubleseeker is offline   Reply With Quote
Old 02-21-2011, 01:22 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
There ya go!
If you feel a need to have the stone backed up for some reason then build a carcass with cement bricks and add the stone to that. You may have to carve the bricks around the existing iron but that would be a whole lot better than using wood.
XXX
Old 03-18-2011, 09:10 AM   #8
Rewards Points: 790
What about using brick and stacking them to form a column....could I use concrete pavers for a stacked column instead of brick?
Old 03-18-2011, 05:23 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I don't see why not. Not really sure what you are trying to do now. Are you talking about using cement bricks for the core-structure?
XXX
Basement Metal Support Post virgolibranyc Building & Construction 4 09-07-2010 03:07 PM
Modified post and beam framing question? diywengr Building & Construction 7 08-11-2010 08:18 AM
Stone or Block Porch Column Scoob66 Building & Construction 0 05-23-2010 11:48 PM
