Wrapping An LVL Beam - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-09-2010, 10:26 AM   #1
Wrapping an LVL beam
Hello, I'll be constructing a large carport that uses LVL beams around the perimeter to support the roof. What are some possibilities for wrapping them that would make sense in this application? They will be riding in Simpson Strong Tie post caps. thanks in advance
diywengr is offline   Reply With Quote
Old 09-09-2010, 10:44 AM   #2
Rewards Points: 558
Why would you want to wrap them?
epson is offline   Reply With Quote
Old 09-09-2010, 10:50 AM   #3
My understanding is LVL should be wrapped for exterior use.
Old 09-09-2010, 11:43 AM   #4
Rewards Points: 558
The only protection that it should have from the weather is during jobsite storage or shipping by being wrapped in order to provide moister protection. Also end a edge sealing of the product will enhance its resistance to moister penetration. If it is left open for exterior use then you would have to apply a sealer for protection. You can contact the suppler for the recommended sealer for their product if required.
Old 09-09-2010, 01:42 PM   #5
thanks for the info
good to know and thanks for the replies. I have an email in to Universal Forrest Products, which is the manufacturer.
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Crawl Space Beam and Joist Support Questions Fire4Effect Building & Construction 5 06-28-2009 01:07 PM
replacing beam in basement bpahwa Building & Construction 4 01-12-2009 07:12 PM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 04:24 PM
Beam Replacement? Steve Dailey Carpentry 5 05-19-2008 08:46 PM
