Would My Basement Leak If I.... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-21-2013, 03:30 PM   #1
Would my basement leak if I....
My parents fought our leaky basement for years and years. My husband and I are now in the planning stages or our new home. We have been talking about having a basement but I always shutter at the thought of a damp moldy wet basement like my parents had. Soooo, my husband suggested we build our 40 X 40 stick built house over top of a 35 X 35 basement. We would be doing as much of the construction that we could ourselves, is there still a good chance that we would still have water problems?
KatCan88 is offline   Reply With Quote
Old 01-21-2013, 05:28 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 606
Huh,..??
Are you sayin', build a Foundation for the house, 'n then a cellar 2, 1/2', Inside the foundation,..??
Or,...
Buildin' the house 2, 1/2' Outside the foundation,..??
If the site is properly graded, 'n not in a swamp, water in the basement is a non-issue....
Sub-grade drainage is placed around, outside the foundation, as an insurance against water...
Puttin' a 2, 1/2" overhang all 'round the house Can be done, but the engineerin' of the Load to the Foundation might get complicated...
In a northern climate, it'll complicate insulatin' too...
Old 01-21-2013, 05:32 PM   #3
Concrete & Masonry
Rewards Points: 526
I don't get it, you wan to cantilever all 4 sides of the house structure over the foundation 2.5' per side, in an attempt to keep it from leaking or being moist???
As long as it's underground, it's going to have the potential to leak and take on more humidity than upper floors above grade. There are a number of precautions that can be taken to avoid these issues though. Good building practices, excellent exterior water proofing, the correct amount of exterior insulation, a good functioning interior & exterior draintile system with a sump crock/pump or drainage to grade, and the correct material next to foundation used as backfill all go a long ways in creating a great basement..........
jomama45 is offline   Reply With Quote
Old 01-21-2013, 07:39 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
proper water proofing and drainage are all you need.
woodworkbykirk is offline   Reply With Quote
Old 01-22-2013, 12:28 AM   #5
I'm by no means an expert but your plan sounds like your leaving potential for much bigger problems than a wet basement. I think you'd be much better off concentrating your efforts on proper sealing, proper drainage, and proper grading.
Evilhomer is offline   Reply With Quote
Old 01-22-2013, 07:30 AM   #6
Rewards Points: 4,534
interesting people still build w/wood when icf's are avail & better imo
i am an expert & we ' wtrproof ' leaky bsmts,,, here's a quik plan: use conc foundation & walls,,, don't backfill for 30d to allow the conc to properly cure,,, prior to backfill, install a toe drain alongside footer lying on #57 stone surrounded by filter cloth,,, this must either drain to daylight OR have a sump & pump to discharge the collected wtr,,, find someone to install a ' rubberwall ' OR coal tar-type waterproof coating,,, protect that w/layer of miradrain,,, backfill in properly compacted ' lifts '
once you add up costs, you'll see why bldrs cut corners - even the bldg code's insufficient,,, $ for granite c-tops appeals more than something covered w/dirt,,, your home has only ONE chance for a dry bsmt & when the foundation's exposed is the time
Old 01-22-2013, 07:53 AM   #7
Rewards Points: 2,516
Thats scary as you are asking about how to properly waterproof the foundation.
hammerlane is offline   Reply With Quote
Old 01-22-2013, 08:15 AM   #8
Rewards Points: 3,130
My wife and I built our log home almost entirely by ourselves, but the foundation was something we left to the pros. Proper waterproofing depends on local conditions and codes, can require equipment and knowledge not useful anywhere else, and, by the way, is a really dirty job. It was worth every penny we paid to return from a 4-month RV trip and find the foundation ready to build on.
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 08:40 AM
Is it leak from the basement or from The Heater? samerhajjaj HVAC 9 11-23-2010 11:13 PM
Leak in basement from time to time. willowgirl Building & Construction 13 12-30-2009 08:32 AM
How to stop a leak in basement wall? Ammons Home Building & Construction 6 03-04-2009 02:24 PM
Leak into basement at bottom of Door deepstuff Building & Construction 8 08-19-2008 02:46 PM
