Would "Great Stuff" Or Equivalent Be Ok For Insulating Rim Joists? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-11-2011, 09:19 AM   #16
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 138
Originally Posted by atxjoe View Post
I can't tell from your description if this would be an issue, but here's my concern: If you create a sealed air pocket where moisture can't escape you may have a mold problem. I was considering insulating under my floor by sealing rigid foam panels between the joists, using great stuff as the adhesive as described here. But that would create a warm, moist, air pocket under the floor and where I live almost certainly breed mold.
I decided instead to use spray foam which will adhere to the subfloor and prevent any mold growth.
I was thinking this but from my understanding the foam is not 100% air tight. It will let air through very slowly so it should not get moist behind there. Someone correct me if I'm wrong on this.
Old 02-13-2011, 07:25 AM   #17
I used polyisocyanurate, with caulk around the edges, then fiberglass batts. Works well. easy to cut in the parking lot also.
mmcgirr is offline   Reply With Quote
Old 02-13-2011, 10:03 AM   #18
I ask the impossible!
Rewards Points: 712
My recollection from reading the buildingscience.com articles was that rigid foam works as an air barrier but not a vapor barrier, so it's good for putting on the outside. I think it explains in the "perfect wall" article.
http://www.buildingscience.com/docum...e-perfect-wall
WillK is offline   Reply With Quote
Old 02-13-2011, 10:13 AM   #19
Rewards Points: 5,336
I used the 2" foil faced polyisocyanurate boards at the rim joists with no trapped moisture issues. I checked 4 of them, 2 in the unheated crawl space.
Ron
Bubba's been here. Repairing sagging rim/floor joists. MattFels Building & Construction 7 02-09-2011 05:28 PM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 08:00 AM
Basement cable location on joists BasementVirgin Electrical 12 02-24-2010 10:56 AM
Floor Joists of different sizes HooKooDooKu Drywall & Plaster 7 02-04-2010 05:43 PM
Sister or Replace Floor Joists brando1118 Carpentry 25 10-26-2008 08:43 PM
