Worth Building A Loft Bedroom - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-01-2012, 12:10 PM   #1
Worth building a loft bedroom
Building 2 bedroom home with future option for 2 bedrooms/office in walkout basement. It would be about 20K to add a loft bedroom. Not sure need, e.g., just another guest room. But if don't build - then roof trusses will be made so that not able to do so in future. Other option is to have them build the roof for future expansion - which still costs around 10-12K. Any opinion on lofts - are they worth it?
nrthwds is offline   Reply With Quote
Old 09-01-2012, 02:53 PM   #2
Rewards Points: 3,130
I wouldn't do it. With the option to ultimately have a 4-br home, $20K more to maybe have a 5-br wouldn't be worth it IMO.
Old 09-01-2012, 03:15 PM   #3
GBrackins's Avatar
Rewards Points: 2,108
not sure what you plan is, but you must have a minimum of two means of egress from the basement (your stairs down to the basement will count as 1). You also have to have an Emergency Escape and Rescue Opening in an exterior wall for each bedroom. The purpose of this opening is to allow firefighters to be able to make an entry into the bedroom from the exterior of the dwelling.
See this link for the requirements based upon the 2009 International Residential Code (basis for most state or local building codes). You code requirements may differ, check with your local building department.
http://publicecodes.cyberregs.com/ic...9_3_sec010.htm
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 09-01-2012, 04:20 PM   #4
I assumed that since the two basement bedrooms are a "future option" apparently being provided by the builder, that egress requirements were considered. But in any case, you are quite correct.
The Following User Says Thank You to md2lgyk For This Useful Post:
GBrackins (09-01-2012)
Old 09-01-2012, 04:31 PM   #5
GBrackins's Avatar
sorry, missed the "walkout" basement, just read basement ..... you are most correct, it should have been planned for
Gary
Old 09-01-2012, 04:32 PM   #6
Thanks. Egress is not problem in basement as it's a walk out and there are windows in all areas that would be rooms; I'd need to put a window in the loft along with stairs; and have the head clearance - all part of the 20K or 10K if leave unfinished.
Old 09-01-2012, 05:25 PM   #7
GBrackins's Avatar
if I had the option of two bedrooms in a walkout basement, or doing a loft bedroom ..... I'd go with the walkout option
Gary
Old 09-01-2012, 05:51 PM   #8
I think there is value in it. It could be a nice master if you add an ensuite. Or it could be a teenage getway or even an office or playroom.
creeper is offline   Reply With Quote
Old 09-01-2012, 05:53 PM   #9
A second floor bedroom is much nicer than a basement bedroom. It will raise the value of the home more as well.
NECHater is offline   Reply With Quote
Old 09-02-2012, 09:32 AM   #10
Originally Posted by nrthwds View Post
Thanks. Egress is not problem in basement as it's a walk out and there are windows in all areas that would be rooms.
Nice, but do they meet the requirements for EGRESS windows? I'd almost bet they don't.
Adding Flooring/Drywall/Insulation in Portable Storage Building Ashley DIY Building & Construction 0 07-12-2012 10:06 PM
building a main and sub panels for 2 remote buildings n175h Electrical 30 12-20-2011 02:09 PM
Old Building problems jake62 Building & Construction 5 08-20-2010 08:32 AM
worth it building a shed instead of buying?? Gnfanatic Building & Construction 15 07-07-2010 11:02 AM
Building in a loft space sgorel Off Topic 3 05-24-2010 05:50 PM
