Woodscrew Or Nails For Shed Foundation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-15-2010, 11:41 AM   #1
Rewards Points: 22
woodscrew or nails for shed foundation
Ok I'm finalizing my materials list for my 7x7 shed. I am going with the skids route on top of cement blocks, with a gravel base for the foundation.
I noticed most shed plans had called for 16d 3'' galvanized nails.
Can I go with some sort of weather-treated type wood screw instead? What are the advantages of screws vs. nails?
Thanks for any insight
nugentoffer is offline   Reply With Quote
Old 04-15-2010, 12:09 PM   #2
Rewards Points: 3,130
Do you want to use screws to fasten down the flooring, or to build the entire shed? They do have the advantage that they won't start coming out like nails can. But they are certainly more expensive than nails. Any screw marked for exterior use would work fine. I prefer the square drive type but that's just a personel preference. And they're generally not called wood screws, but rather deck screws or construction screws.
It probably doesn't matter for a small shed, but for house framing, screws are actually not code approved.
Old 04-15-2010, 12:27 PM   #3
Old School
Willie T's Avatar
As stated above, screws are not code approved for general structural construction. This is because they are not strong in sheer and twisting situations. Screws mostly snap in half. Nails bend.
Willie T
Old 04-15-2010, 05:56 PM   #4
Civil Engineer
Rewards Points: 4,566
Willie T, did you mean to say "nails are not code approved for structural construction?" I assume you meant screws. This is incorrect, there are many screws that are rated for structural construction, see the Simpson catalog, where they list no less than 4 different types of fully rated screws that are suitable for structural use with their products. It is true that most codes do not discuss use of screws, other than to require that they be rated, however just because there is a table for nails and NOT one for screws does not mean screws cannot be used. You simply have to use appropriately rated size and type.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
Willie T (04-15-2010)
Old 04-15-2010, 08:41 PM   #5
Registered User
Rewards Points: 5,212
Not to nit-pick, but "fully rated screws that are suitable for structural use with their products". Not much construction framing I've seen since '73 with screws, other than Simpson on their connectors. (Or in deck boards) Not many connectors $ in a shed, unless mucho dollaros, then you would hire it out..... Screws have their place, and nails go anywhere. Make sure they are rated for the new treated wood, nails or screws.
Be safe, Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Old 04-15-2010, 08:47 PM   #6
Old School
Willie T's Avatar
Thanks guys. Yeah, I meant screws. (I corrected it) And as Gary said, I meant for general 2x to 2x framing connections. Don't put your studs and rafters in place with screws.
Willie T
Round House Foundation Feasibility Mswick Building & Construction 23 02-27-2010 09:34 AM
Foundation Repair Help rasilun Remodeling 1 10-15-2009 11:26 PM
How to add footing and foundation to existing foundation? ptcamaro Building & Construction 6 06-22-2009 11:22 AM
What nails to use? 2x4 framing, osb sheathing jw15842 Carpentry 6 09-08-2008 11:31 PM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 09:39 AM
