-   -   Wooden treated posts in a pole barn (http://www.diychatroom.com/f19/wooden-treated-posts-pole-barn-123248/)
Paintedpaca 11-12-2011 04:39 PM
I've just built a medium sized wooden pole barn using 4x4 treated posts to support the ridge beam. It has been up two months and I've just recently noticed a lot of small and some large stress cracks running up and down the length of all the posts. I expected a fex cracks. But what concerns me is the high number of small cracks in all of these supporting posts. I am wondering if the beam and the roof are too heavy and the posts are actually compressing and fracturing under the weight. This is what it looks like! I am scared! I think I may need to re-inforce all these posts with additionsl posts or with kiln dried 2x4's all around them, and put them in a cement post. I'm afraid the roof is goping to come crashing down on my animals inside. Can you help?
concretemasonry 11-12-2011 05:13 PM
For your application, a 4x4 could be a little skimpy and a 6x6 would be a better choice.
Putting the post into concrete because they tend to rot where they are embedded because of the alternating wet and dry and temperature variations in some climates. Embedding has been successful when old growth wood was available, but that is getting tough to get. Without knowing the height, location/climate and building size it is hard to give a firm answer. For just a pole barn, I would not worry too much about some cracks and checking as the treated (I assume) wood dries out.
Dick
Joe Carola 11-12-2011 05:28 PM
Who designed this?
Daniel Holzman 11-12-2011 07:07 PM
It does not appear you posted a location, any details of the size of the building, or any photos. You also did not discuss the design of the barn (i.e. who designed it, who built it, who approved the plans?). In other words, you have provided no usable information to assess whether the 4x4 posts are adequately sized. Pressure treated lumber is notorious for cracking as it dries, especially if it was wet when purchased (this is common). The cracks may not be significant, but this will require at a minimum the information indicated above to assess.
