Old 04-07-2006, 05:19 PM   #1
ssc
wooden platform on concrete
i want to build a wooden platform on top of concrete. i was told to 1st put down plastic so the wood does,t rot out. do i need to use pressure treated wood(2by6) or can i use regular (2 by 6 s ) . i was just going to lay down the 2by6 flatevery 4 /6 inches qnd go over it with 3/4 plywood putting screws 2 inches. it will be covered with a building but not heated to hot. i live in PA.it get very cold in the winters. will this warp or will it stay pretty flat that is my main concern , flatness
ssc is offline   Reply With Quote
Old 04-07-2006, 08:54 PM   #2
Contractor
tgeb's Avatar
I would not put plastic down, but I would use treated lumber. The plastic can not only keep moisture away, it can also trap moisture around your lumber. Don't forget about insects that would like to eat that lumber. Go with the treated. You could probably use 2X4 lumber though from what you have described. Might be cheaper.
Tom
Tom
tgeb is offline   Reply With Quote
Old 04-07-2006, 09:03 PM   #3
I opt for the treated, but I'm sure in some parts it is allowed to use s.p.f. If you use treated make sure it is dry enough so there isn't excessive shrinkage after installation. This may take several weeks depending on moisture content...
Bob
bob the builder is offline   Reply With Quote
Old 04-08-2006, 08:54 AM   #4
ssc
so just put the treated lumber on the concrete with nothing under it.
Old 04-08-2006, 10:58 AM   #5
Contractor
tgeb's Avatar
You got it!
You might consider putting some kind of venting so it can breath a little under there, so moisture if it does get under will not cause problems later on.
Tom
Tom
Old 04-08-2006, 04:40 PM   #6
747
registered
747's Avatar
A rule of thumb is always go with PT lumber when its in contact with cement. Also if your thinking about painting the platform you must wait a considerable amount of time before preceeding.(months)
747 is offline   Reply With Quote
Old 04-09-2006, 11:21 AM   #7
Darylh's Avatar
I would at least put tar paper down before the pressure treated wood and 2x4 every six inches will be extremely strong.
Darylh is offline   Reply With Quote
Old 04-09-2006, 11:15 PM   #8
renovations
Why would you want 2x4 more frequently than 16"o/c? Unless you've got some nasty point loads 3/4" ply can easily span the remaining 12-1/2". Ventilation under there is going to be an issue, if it gets, and stays, moist, the plywood will rot out on top of the pt sleepers. My $0.02
Bonus is offline   Reply With Quote
Old 04-10-2006, 10:21 AM   #9
Darylh's Avatar
I built a huge sunroom about 8 years ago and what I did(code requirements) was I layed tar paper all over the concrete slab then layed 2x4s flat 4 feet on center then ran 2x6 16 inch on center. I put a 2" plastic soffitt venting around the outside nailed to the but ends of the 2x4s. In your case your wanting to run just 2x6 on flat so the soffitt venting should work the same just make sure it all flashed properly..
Old 04-11-2006, 04:14 PM   #10
ssc
you didn't use pressure treated wood
Old 04-17-2006, 10:02 AM   #11
Darylh's Avatar
Yes I sure did I also used 3/4" t&g select plywood and
talk about solid as a rock.
I also Insulated the floor to but I made up some wooden
blocks to keep the Insulation off the concrete and create some air flow.
What goes through my mind is when ever building a floor on a concrete slab
there is not going to be any excess to it so build it extremly strong,
insulate it ventalte it and use the very best in Material
then you won't ever have to worry about it later.
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 10:38 AM
Concrete walls on wooden joists stonehanger Building & Construction 3 11-24-2006 05:26 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 05:48 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
